Author Topic: Tow Hooks  (Read 26971 times)
Offline michael.francis.5876
Tow Hooks
« on: January 12, 2015, 07:54:44 pm »
I have a 1976 Chevy K10 and I am looking for a set of front tow hooks. It looks like my bumper has a cut out for them and there are some holes on the frame where it looks like they bolt on but I cannot seem to find them online.
Offline fitz
Re: Tow Hooks
« Reply #1 on: January 12, 2015, 08:35:02 pm »
Any pictures of your bumper?
Offline Jason S
Re: Tow Hooks
« Reply #2 on: January 12, 2015, 08:49:30 pm »
From what I can remember, the tow hooks I used on my '74 K-10 were 'take-offs' from a 88-98 Chevrolet K-series pickup.  They bolted in perfectly.  I can grab some additional photos if you'd like.
Here is what my setup looks like:
Re: Tow Hooks
« Reply #3 on: January 12, 2015, 09:05:02 pm »
my 91 v3500 look likes what jason has posted also
Offline enaberif
Re: Tow Hooks
« Reply #4 on: January 12, 2015, 09:40:00 pm »
Good luck finding a OEM set of hooks for the 73-80 trucks. They about as rare as a unicorn and if you find a pair grab em quick!
Offline FlatBlack77
Re: Tow Hooks
« Reply #5 on: January 12, 2015, 10:26:19 pm »
the ones Jason has are exactly like the set i got
only i was told they were from an S10(no idea what year)
and mine had a second part like a backing plate with 2 threaded holes so they "clamp" onto the frame. or sammich the fram between the 2 parts.
they bolted right on my 79 K10
Offline enaberif
Re: Tow Hooks
« Reply #6 on: January 12, 2015, 10:36:47 pm »
The problem with tow hooks like that is they get bolted onto the truck and they are weaker in how they are bolted on than they originally are.
You have more downward and forward motion pulling on those tow hooks than if they were placed sideways like tow hooks on a GMT400 truck.
Offline FlatBlack77
Re: Tow Hooks
« Reply #7 on: January 12, 2015, 10:43:02 pm »
thats true but they are easy to come by and are a good fit. they will get some moderate pulling done
if you are going to be putting some serious stress on them than you should probably be thinking about something else anyway
Offline enaberif
Re: Tow Hooks
« Reply #8 on: January 12, 2015, 10:59:36 pm »
I have a set of these from a truck I found in the junkyard... I would trust them FAR more over the GMT400 ones..
http://www.harborfreight.com/10000-lb-capacity-tow-hook-kit-67497.html
Re: Tow Hooks
« Reply #9 on: January 12, 2015, 11:08:01 pm »
these are about the same size as the ones on mine. along with the hitch receiver
Offline timthescarrd
Re: Tow Hooks
« Reply #10 on: January 13, 2015, 12:02:58 am »
The R/V 1500 suburban I got my grille guard off of at a junk yard had a set of hook that I assume were OEM, they bolted to the frame where the bumper mounts bolted on, and the plastic air dam had two openings for them. Guess I should of grabbed them
Offline LTZ C20
Re: Tow Hooks
« Reply #11 on: January 13, 2015, 01:08:26 am »
I have a set of hooks off a 97 tahoe 4wd, they look identical to the ones FlatBlack posted and include the bolts and backing plate he also mentioned. I have not mounted them, just been hangin out in my garage somewhere. I would trust them, they are very strong and if bolts worry you than get some bigger and stronger bolts or weld it to the frame.
LTZ Cheyenne C20
Offline roundhouse
Re: Tow Hooks
« Reply #12 on: January 13, 2015, 06:31:24 am »
You do not want $6 made in china tow hooks !!!
Re: Tow Hooks
« Reply #13 on: January 13, 2015, 11:06:59 am »
Offline fitz
Re: Tow Hooks
« Reply #14 on: January 13, 2015, 11:21:35 am »
Get a set off a CUCV.
