Author Topic: Lowering question  (Read 8265 times)
Offline JoshsC10
Lowering question
« on: January 13, 2015, 11:26:47 am »
I just installed belltech 4/6 kit , with 3" lowering spindles and 1" lowering springs but I really want it to come down maybe 2 more inches in front should I just cut a spring to bring it down a little more?? Or any other suggestions?? Thanks
Re: Lowering question
« Reply #1 on: January 13, 2015, 09:36:34 pm »
Have you driven it yet?  A 4/6 kit should put the truck about level.
Offline FlatBlack77
« Reply #2 on: January 13, 2015, 10:32:34 pm »
get 3 inch springs if you really want to be lower
Offline JoshsC10
« Reply #3 on: January 15, 2015, 08:48:23 pm »
How many leafs should be on an 83 c10?
« Reply #4 on: January 15, 2015, 09:48:55 pm »
3 for STD, 5 for HD
Offline JoshsC10
« Reply #5 on: January 16, 2015, 09:09:50 am »
3+the overload?
« Reply #6 on: January 19, 2015, 10:50:52 am »
Correct.
Offline 1979cheyenne
« Reply #7 on: January 26, 2015, 11:26:13 pm »
i cut 2 coils and am going to have to modify stock bump/steering stops. After test driving me and my friend were sitting next to my truck and the front dropped a good 1.5-2" and sounded like the coils broke but they are fine (scared the heck out of us). I recommend driving on one cut coil maybe a only half for a day or two if you do cut it. It's easier to remove them and cut more than ordering a new pair because you cut too much. (My opinion)
« Last Edit: January 26, 2015, 11:28:03 pm by 1979cheyenne »
« Reply #8 on: January 27, 2015, 01:12:47 pm »
When it dropped it settled which is why I recommend driving it first.  I also recommend cutting only a 1/2 coil first and then drive it and remove and cut a 1/4 off drive it etc until you get it like you want.  Don't cut more than 2 coils you will hate the ride and alignment will be a major pain.  I really recommend not cutting over 1.5 coils, but...
Offline JoshsC10
« Reply #9 on: January 27, 2015, 03:18:15 pm »
Thanks I don't think I'm going to mess with cutting them. I'm Sure my leaf springs are crap, I'm going to order a new set, I think it will raise the rear a little maybe leveling it out better if it doesn't then I might just get 2-3" lowering springs for the front.
