Author Topic: 10 bolt vs 12 bolt vs 14 bolt?  (Read 28363 times)
Re: 10 bolt vs 12 bolt vs 14 bolt?
« Reply #15 on: January 18, 2015, 03:07:41 am »
i would try to talk him down. the most i would pay is 400. that being said offer him 300
Offline roundhouse
« Reply #16 on: January 18, 2015, 06:07:14 am »
15" 8 lug wheels are rare
And also may not fit over the calipers on the front
« Last Edit: January 18, 2015, 09:36:10 am by roundhouse »
« Reply #17 on: January 18, 2015, 08:42:49 am »
grind the calipers
Offline moneyg77
« Reply #18 on: January 18, 2015, 07:45:20 pm »
After some back and forth we finally agreed on $450. This guy DID NOT want to budge on the price..which is understandable. And the reason he sold them at that price is because he has 6 dana 44's, 4 14 bolt ff, and 2 14 bolt sf.
He bought the axles from a friend of his. I guess the story is that guys engine blew and was so pissed that he parted out his entire truck. IMHO, what a stupid decision!! But worked out for me, since they were on a daily driven truck just a couple months ago..not sinking in dirt for 15 years like another set that I found.
I was able to get the wheels for $100. He had 3 sets of them. The ones I bought were sandblasted and powder-coated black.
grind the calipers
Where should I grind? Is there a link to pics of where they should be grinded?
1981 K-10 longbed stepside 350/465/208/quadrajet. 6"lift, 35" BFG, custom exhaust
1983 K-10 swb 4"lift
1986 lwb fleetside
« Reply #19 on: January 18, 2015, 09:20:18 pm »
the reason he has so many is because hes asking too much lol.
now this is for a dana 60 its the same ideal but the 60 is thicker so you have to grind more off you wont have to grind this much
i would imagine it amount also depends on your back spacing on your rims also.
do you know what it is?
http://www.pirate4x4.com/tech/billavista/60_front/index2.html
Offline moneyg77
« Reply #20 on: January 21, 2015, 01:01:47 am »
I was finally able to take the rear diff cover off and I am shocked!!!!
1986 lwb fleetside
Offline moneyg77
« Reply #21 on: January 22, 2015, 12:09:01 am »
From what I could get without removing the ring and pinion, the numbers on the ring gear read (41 10 81 (41/10=4.10)) and the pinion (10 15 41 (41/15=2.73)). When I get pictures I'll post them of the numbers i could see. Anyone know what those numbers mean? Hopefully im wrong but it looks like theres a 2.73 pinion matched to a 4.10 ring gear...please please tell me i'm reading wrong or ive mistakenly did the math with the numbers.
1986 lwb fleetside
« Reply #22 on: January 22, 2015, 12:21:19 am »
if you count the teeth on both and divide 41 by the pinion number it should tell you
« Reply #23 on: January 22, 2015, 12:21:43 am »
also you might want to check your front now
Offline roundhouse
« Reply #24 on: January 22, 2015, 07:09:55 am »
Here's a chart
http://www.quadratec.com/jeep_knowledgebase/article-137.htm
Offline roundhouse
« Reply #25 on: January 22, 2015, 07:14:23 am »
how many teeth on each one ?
Use a grease pencil or fingernail polish to mark one tooth do you can count em
Mine was easy since it was missing half a tooth on the pinion
Offline moneyg77
« Reply #26 on: January 22, 2015, 06:57:23 pm »
i counted the pinion/ring gears and they are matching 2.73 gears
1986 lwb fleetside
Offline moneyg77
« Reply #27 on: January 23, 2015, 01:32:33 am »
So for the replacement Dana 44 and 14 ff that I'm installing is there anything I should know(steering, suspension, brakes...anything)?
1986 lwb fleetside
« Reply #28 on: January 23, 2015, 04:16:00 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28592.0
this is about brake systems.
plastic reservoir its a JB3, JB5 or JB6
JB3 BRAKE, POWER, DISC/DRUM, 4600 LBS
JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
JB6 BRAKE, POWER, DISC, DRUM 7200 LBS
so your setup should be good with just swapping axles. steering should all be the same and so should suspension.
Offline moneyg77
« Reply #29 on: January 23, 2015, 04:56:53 am »
That's good news! Which brakes do you recommend?
1986 lwb fleetside
