Author Topic: 10 bolt vs 12 bolt vs 14 bolt?  (Read 28362 times)
Offline moneyg77
« on: January 14, 2015, 01:59:59 am »
So im in need of a rear end rebuild. I have an 81 k10 longbed stepside 350,4spd, 208 w/ 6'' lift and 35's . For the longest time ive been debating just rebuilding my current 10 bolt w/ 3.73's vs finding a 12 bolt (which i found 2, $170 per). then i found a 14 bolt from a chevy van 2500 for $150 on cl. Any suggestions? All help is appreciated.
1981 K-10 longbed stepside 350/465/208/quadrajet. 6"lift, 35" BFG, custom exhaust
1983 K-10 swb 4"lift
1986 lwb fleetside
Re: 10 bolt vs 12 bolt vs 14 bolt?
« Reply #1 on: January 14, 2015, 05:41:18 am »
i would go with the 14 bolt BUT its going to be a 8 lug axle. then you need to match the ratio so you need to buy a 8 lug front axle. then you need new tires/rims
Offline moneyg77
« Reply #2 on: January 14, 2015, 06:54:43 am »
Why would I need new tires?
1986 lwb fleetside
« Reply #3 on: January 14, 2015, 07:55:22 am »
16" rims for the ¾ vs 15" for the ½ ton. you can get 15" 8 lug but now your talking about more money
Offline Jason S
« Reply #4 on: January 14, 2015, 09:14:45 am »
You might want to check overall width and spring spacing for the van 14-bolt before purchase. I seem to recall there were some differences between the truck and van axles...
Since you're looking and researching, many of the 88-up Chevy/GMC light duty 2500 (and some 1500 trucks) had a 6-lug, semi-float 14-bolt rear axle. It would be stronger than the 10 or 12-bolt, but it'd require moving the spring hangers and shock mounts.
« Reply #5 on: January 14, 2015, 02:51:29 pm »
88+ are a different width i think
Offline moneyg77
« Reply #6 on: January 14, 2015, 08:47:09 pm »
Ok, so it might be a no go. His 14 bolt is off of an '01 chevy van..i might just go with the 12 bolt posi's i found.
1986 lwb fleetside
Offline Jason S
« Reply #7 on: January 14, 2015, 09:47:41 pm »
There is a slight difference in the 88-up truck versus the 73-87.
My $0.02,
If you're going to keep the 6" lift and 35's, then a 14-bolt would be the better long term solution.
Here's a recent thread in case you missed it:  http://forum.73-87chevytrucks.com/smforum/index.php?topic=30117.0;topicseen
Offline roundhouse
« Reply #8 on: January 15, 2015, 09:33:18 am »
http://offroaddesign.com/catalog/14boltspringperches.htm
Buy these
Cut off the old ones
Bolt the 14 ff under your truck with the driveshaft installed and get he pinion angle wjere it should be and tighten down U bolts
Have a mobile welder come over and weld it
We are doing that now.  But I actually found non running a k10 wih a FF14 in with the perches and shock mounts relocated and the hub modifed so the wheel has  the same  width as the front axle
 so we bought it as a parts truck
You will have to get  different rims and maybe different tires
You can buy aftermarket steel 15" rims that are 8 lug
But sometimes 15" won't fit on a FF axle and you also gotta swap the front hubs and rotors to 8 bolt
Someone on pirate is selling a kit to convert the FF14 to 6 lug AND disc brakes for about $350
That's a deal. You're gonna spend more than that switching to 8 lug rims
Plus 16 inch tires cost $100 each more than 15"s
« Last Edit: January 15, 2015, 02:24:56 pm by roundhouse »
Offline ehjorten
« Reply #9 on: January 15, 2015, 09:36:32 am »
If I was going to do something custom and put a little bit of welding work into it to make it fit, I would do the AAM 14-bolt axle out of the 2001 and newer trucks.  There are 2 versions: the 2nd generation 11.5 AAM and the 3rd generation 10.5 AAM.  These axles are similar to the Corporate 14-bolt, but they do not have the support bearing for the pinion like the Corporate 14-bolt.  These axles have the advantage of having factory disc brakes and also the ability to run an e-locker!
« Last Edit: January 15, 2015, 09:38:04 am by ehjorten »
-Erik-
« Reply #10 on: January 15, 2015, 07:20:17 pm »
by time you do all this you could buy a matching set of 8 lug axles for $250-$500 but then you have to get new rims and maybe tires. you can pick up a matching 6 lug for prob a little less then the 8 lug axles and keep your rims and tires and be done
Offline roundhouse
« Reply #11 on: January 16, 2015, 09:20:43 am »
Yep
We swapped in 8 lug axles
Before I realised that 16 " tires are $100 more than 15s
What a ripoff.   There is actually LESS material in the tire but it costs more
Every inch increase in rim diameter above 15 adds $100 to a tire
We blew two 12 bolts driving totally normal on paved roads with 33s
So no real choice but to go 14 bolt
Silly me.   Thought a 12 bolt was as good as a 9" ford
Offline moneyg77
« Reply #12 on: January 18, 2015, 01:32:16 am »
Im kind of excited guys, for once in all the chaos. I found dana 44/14ff axles off of a 77 3/4 ton. I also found 8 lug 15" wheels in the same town my parents live. Did I find something promising? I started a separate post asking what I should offer for the axles. They have 3.73 gears and came off of the same truck. Thanks
1986 lwb fleetside
« Reply #13 on: January 18, 2015, 02:17:57 am »
how much are they asking?
i think a good price is $250-$300
cant remember since its been so long but i picked my set up with 4.10 for 200 or 300 at a junkyard. knew the people and one boy who worked there was my childhood best friend and he was at one point (when his dad passed) co-owner of the place.
Offline moneyg77
« Reply #14 on: January 18, 2015, 02:48:06 am »
They're asking 500 for the axles and 150 for the wheels, two different sellers
1986 lwb fleetside
