Author Topic: Looking for ideas on replacement of spare tire  (Read 12457 times)
Offline srozell
    • My 1980 Chevy
« on: January 15, 2015, 03:59:52 am »
I don't like having my spare under my truck. In my experience, I never get a flat on dry pavement, it's always in the mud or crud, and usually when I'm dressed for a wedding or a funeral. I'm looking for optional placement ideas that don't take up too much (if any) bed space.
I'm almost tempted to bolt it to the top of the cab.
Does anyone have any better ideas?
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
Offline roundhouse
Re: Looking for ideas on replacement of spare tire
« Reply #1 on: January 15, 2015, 07:32:48 am »
Using the cable winch mount from a later model suv or minivan?
Anyone tried to mount one inside the bed like the old station wagons ?
The old wagons had the spare tire right inside the car right behind the rear wheel
In a hole made for it
Where the tire drops down outside the frame rail but inside the truck bed ?
So it doesn't stick up over the side ?
Offline Jason S
« Reply #2 on: January 15, 2015, 08:50:33 am »
Quote
Some alternative locations I've seen:  Mounted vertically in the bed in the corners, mounted on a headache rack behind rear window, mounted on a headache rack over cab, mounted on a brush guard in front of radiator, swing out mount attached to rear bumper.
Quote
The old wagons had the spare tire right inside the car right behind the rear wheel. In a hole made for it
Like the setup on a Suburban?
Offline roundhouse
« Reply #3 on: January 15, 2015, 09:14:00 am »
Quote
Quote
I guess
I actually had a Burb.  But have no recollection of the spare tire mount
If its like a blazer it just bolts to the inside
Offline srozell
    • My 1980 Chevy
« Reply #4 on: January 16, 2015, 02:09:51 am »
Thanks Jason S, I didn't even consider using a headache rack. That should work well.
1969 K20 Step Side
Offline Jason S
« Reply #5 on: January 16, 2015, 08:27:02 am »
You're welcome.  Take photos of whatever you come up with, we'd all like to see.
Offline roger97338
« Reply #6 on: January 20, 2015, 11:34:38 pm »
I'm just thinking outside the box here, but how about a compact spare stuffed behind the seat? I used to have a late 90's Trans-Am; The compact spare in it came deflated with a can of something or other to inflate it.
Or, you could get AAA. And, like, maybe a satellite phone.
Fictional interaction:
I'm Roger, and I'm an alcoholic.
This is Triple-A, not AA.
I'm Roger, and I'm planning a trip.
Offline srozell
    • My 1980 Chevy
« Reply #7 on: January 22, 2015, 06:36:09 am »
That gave me a good laugh, then I got worried and thought your were serious, then I laughed again.
The compact tire thing is a great idea actually. If I had enough of them I could stack them up and use them for axle-stands in a pinch.
1969 K20 Step Side
Offline roger97338
« Reply #8 on: January 24, 2015, 09:58:42 am »
I'd never have thought a 4WD could use a compact spare; Then, I discovered my Mom's Pathfinder has a compact spare tire. It's not the tiny little donut, but it isn't a full-sized tire, either.
« Reply #9 on: January 24, 2015, 10:21:16 am »
Space saver spares in full sized GM cars are skinny and fairly tall and does fit behind the seat but if you need the seat all the way back it wouldn't work out.  I am referring to 1/2 Ton 2 wheel drive 5 on 5 bolt pattern
Offline srozell
    • My 1980 Chevy
« Reply #10 on: January 24, 2015, 01:03:14 pm »
Well, interesting. I would never have thought.
That won't work for me as I do need the seat all the way back.
There seems to be trade-offs everywhere. It's a tough decision really.
1969 K20 Step Side
« Reply #11 on: January 24, 2015, 04:58:15 pm »
Another option would be to install bucket seats and put it behind the passenger side... Just a thought
Offline Stewart G Griffin
« Reply #12 on: January 26, 2015, 05:50:02 pm »
 Astro vans also had the 5X5 donut spare......and yes i tried putting behind the seat....and no if won't fit if you want your seat all the way back.
Offline purposefed
« Reply #13 on: September 02, 2015, 04:58:29 pm »
Could mount it under the bed but access it from in the bed, like Honda Ridgelines do. The problem with that would be when you get a flat while carrying something in the bed, you'd have to unload the bed. A solution could be to hinge both the top and bottom, weather sealing both, and if the flat happens when you're not hauling something, you don't have to get dirty, and when you are, access is still simple.
