Author Topic: 87 p/u won't start  (Read 28413 times)
Offline Tjerica1201
Re: 87 p/u won't start
« Reply #45 on: February 09, 2015, 09:33:39 pm »
Makes sense. A pressure test that LTZ will eliminate that as an issue i the test shows normal. I'll try that this weekend. Gotta figure out which hose goes to that tank. I could always unplug one and click the key on and if I get soaked, I got it right. Haha
Offline LTZ C20
« Reply #46 on: February 09, 2015, 11:22:31 pm »
Usually it's the the biggest hose from the pump going to the switching valve.
LTZ Cheyenne C20
« Reply #47 on: February 10, 2015, 04:37:32 am »
theres a difference in flow vs pressure. if the hose is cracked you might have the flow but not the pressure cause the hose wont split till it builds up pressure
« Reply #48 on: February 19, 2015, 11:34:05 pm »
I just wanted to throw this out there.  I wouldn't use the provided hose with the pump.  If you are where E85 is used it will eat it up.  I would buy some submersible E85 safe hose.
