Author Topic: drum brake backing plates  (Read 4952 times)
Offline jg1977c20
« on: January 18, 2015, 01:26:29 am »
Wasnt sure where to post this  anyne know where to get new backing plates for the rear drums , mine are the 13 in drum with 13x2.50 In  shoes.        77 c20 cheyenne camper special     or what other years will fit from the wreckers
thanks in advance
1977 c20 cheyenne camper special 8200gvw
Re: drum brake backing plates
« Reply #1 on: January 18, 2015, 02:26:21 am »
dont know to tell you the truth. the only places i have been able to find the backing plates is off other axles.
Offline jg1977c20
« Reply #2 on: January 18, 2015, 02:31:44 am »
yeah ive searched pretty intensly for new ones - mine arent rusted or anything but probably the pads that the shoes rest on are worn being this a 40 year old truck .
« Reply #3 on: January 18, 2015, 03:04:42 am »
wheni changed mine out it was cause i changed axles and the axles i used were a step down in pad size so i changed them to keep the same pads
Offline Jason S
« Reply #4 on: January 18, 2015, 08:56:40 am »
 Have the shoes really worn the backing plates to the point that they need replacing? Other than age, is there any other reason that you're wanting to change the backing plates?
Offline jg1977c20
« Reply #5 on: January 18, 2015, 03:54:51 pm »
no other reason than just the wear from the shoes -they arent flush yet but they def look worn
« Reply #6 on: January 19, 2015, 10:32:15 am »
Unless they are worn through I wouldn't worry about replacing them.  Post a pic.
