Author Topic: 91 V3500 Crew cab cummins  (Read 102688 times)
« on: January 18, 2015, 10:20:27 pm »
The long wait is about over. i pulled my 84 k30 cummins into the shop tonight and started to pull her. the only thing left is the trans bolts. wanted to wait till i had a helping hand before i tried to pull it but let the fun commence. plan is to get it pulled tomorrow then ill pull the 350 out of my crew cab
it is tightly fitted into the engine bay i noticed tonight just how tight. i dont think ill be able to pull it like you would a normal engine. the exhaust manifold is about 1/4" from the firewall and the bottom of the fire wall has been cut out. might have to remove the engine mounts jut to get it out
« Last Edit: January 18, 2015, 10:33:25 pm by Irish_Alley »
Re: 91 V3500 Crew cab cummins
« Reply #1 on: January 18, 2015, 10:31:14 pm »
The crew
Offline fitz
« Reply #2 on: January 19, 2015, 07:35:07 am »
This will be a great build to follow.
I'm looking forward to the updates.
« Reply #3 on: January 19, 2015, 09:58:09 am »
So you are swapping the motors from one to the other or?
« Reply #4 on: January 19, 2015, 12:05:14 pm »
im at least pulling the 350 out of my 91 and putting it in my 94 swb that has a 4.3 or i will just put it in the 350 84. if i put the 350 in my 94 that brings me to my next issue not sure what im going to do with the 84. i know i just got it but dont want to get rid of it, my buddy that i weld with wants it he has a 5.3 to drop in it and wants me to give it to him. but its worth $1500 i cant just give him that type of money lol.
but i have 5 trucks right now and once this swap is done my crew will be everything so i dont really need 3 lwb 4x4. but the 84 is my birth year and besides my crew cab its my only dana 60. my other lwb are my 86 thats sitting on a k20 axle (my first square and first truck i really had) my 79 k20 (mud truck thats needs a new front axle)
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #5 on: January 19, 2015, 12:44:25 pm »
To many trucks not enough time...........welcome to the 73-87 website LOL. It's great how you keep us posted on all your projects very interesting keep up the great work!!
Offline Dr_Snooz
« Reply #6 on: January 19, 2015, 10:19:16 pm »
That's a veeeery tight fit. How'd you get that in there?
« Reply #7 on: January 20, 2015, 12:08:40 am »
i didnt put the cummins in the 84 thats how i got it.
one part that is "rigged up" is the flex plate
they had to make the bolt holes on the flex plate close to the inside so they welded in washers. this is something that i want to better lol
Part of the fire wall had to be cut out
Dont know if this throttle cable is oem but its total length is about 39"
« Last Edit: March 21, 2015, 11:08:54 pm by Irish_Alley »
« Reply #8 on: January 20, 2015, 11:52:40 am »
so i got myself a little pre-tax check gift
now if i only had a pillar pod. but something i noticed i dont have the screw holes in my pillars. i really dont want to mount anything in the dash cause it doesnt look that clean
« Reply #9 on: January 20, 2015, 11:54:12 am »
once i get my 94 back from the in-laws i think im going to pull the front clip off the crew just to have more room.
Offline Dr_Snooz
« Reply #10 on: January 20, 2015, 09:58:35 pm »
My bad, sorry. Still a tight fit though. I'm surprised there aren't some gouges on the firewall.
« Reply #11 on: January 21, 2015, 12:14:48 am »
lol its ok. but they did have to cut the firewall at the bottom where the two top trans bolts go. and the very top of the firewall near the cowl is dented for some off reason.
« Reply #12 on: January 21, 2015, 01:35:22 pm »
fast shipping got them today :-)
« Reply #13 on: January 22, 2015, 07:09:03 pm »
what do you mean you don't have screw holes in your pillar?
I should have a number of pillar pods in March.
« Reply #14 on: January 22, 2015, 08:37:33 pm »
theres no interior or holes for screws lol. thought they all came with at least screw hole. unless they got covered up at some point.
