Author Topic: Volt meter in dash not working  (Read 4769 times)
Offline Shurman86
« on: January 19, 2015, 01:13:44 pm »
I have a 1986 K10. The volt gauge in the dash is not working. I took it out and connected to the battery with some wire leads and the needle moves and seems to be working fine. I have 14 volts at the battery and 15 volts at the alternator but only 6 volts at the socket in the cluster that the gauge plugs into. I dont understand why I'm only getting 6 volts. Any ideas on what may be the problem? Thank you for your help
Offline 4lowman
  • Oldguy
Re: Volt meter in dash not working
« Reply #1 on: January 19, 2015, 05:26:13 pm »
 Bad connections or bad wires. Go to the source and check back to the meter.
« Last Edit: January 26, 2015, 07:35:19 pm by 4lowman »
Each day is a gift. So make the best of it! And that can happen with a 4x4 Burban.
Offline ackland3
  • Shade Tree Certified Mechanic
« Reply #2 on: January 19, 2015, 09:51:02 pm »
Possible short?
1985 K10
305
