Author Topic: Leaf spring help!  (Read 4834 times)
Offline dylan.hodges.92
Leaf spring help!
« on: January 19, 2015, 07:24:54 pm »
My dad ordered a 3/4 ton 4" lift from super lift and we went to install it and realized that the new springs were 2 1/2" while the original ones are 2 7/8" his title says k20 so are 1 tons springs wider? Did someone swap out the springs for wider ones?
Offline illinoisk30
Re: Leaf spring help!
« Reply #1 on: January 20, 2015, 05:09:59 am »
I have several trucks with lift kits from suspension lift company's and every one I have received are narrower just like you are describing. The new springs are narrow but the bushings that are in the end of the spring usually are the correct width to fit in the shackle or spring bracket. You should not have any problems as long as you ordered them for the right make and model.
      I am not sure if the weight rating is the same or not. The new springs are arched more and probably have more springs than the original factory so I would think it would be the same or heavier. Hopefully  this helps, some other guys will chime in if this is not satisfactory.
1977 Chevy K30 DRW 400 TH400
1978 GMC K35 SRW 454 TH400
1979 GMC K35 SRW 400 TH400
1980 Chevy K30 SRW 350 SM465
« Reply #2 on: January 20, 2015, 11:52:52 am »
Thanks!! I did some more checking and just like you said the bushings fit its just the springs that are narrower.
Offline illinoisk30
« Reply #3 on: January 20, 2015, 12:42:09 pm »
Good,  I'm glad that helped. Have fun and be careful.
« Reply #4 on: January 20, 2015, 06:57:16 pm »
Having fun an being safe don't normally go together in our garage. Lol
