Author Topic: No fuel  (Read 4673 times)
Offline Nj1986k10
No fuel
« on: January 20, 2015, 06:10:02 am »
My 1986 chevy k10 with a sbc 350 recently stopped running. Its not getting fuel. If i pour fuel in the carb it runs. What should i check first? The fuel pump or the lines. Also is there anything else in the fuel system that could go bad and cause it to not fun? It sat for a year in a driveway so i was thinking it may just be gunked up but im not sure
Re: No fuel
« Reply #1 on: January 20, 2015, 11:40:30 am »
a little more info. carb or tbi, electric pump or manual?
Offline Nj1986k10
Re: No fuel
« Reply #2 on: January 20, 2015, 12:34:15 pm »
Carb and manual
Re: No fuel
« Reply #3 on: January 20, 2015, 12:36:28 pm »
could be a clogged filter. what type of carb? take the inlet line off the carb and have someone turn it over see if you can get any fuel from there (try to catch the fuel with a bottle)
Offline Nj1986k10
Re: No fuel
« Reply #4 on: January 20, 2015, 01:12:14 pm »
I believe its a rochester carb. Also the manual pump is the one that gets hooked up on the motor right?
Re: No fuel
« Reply #5 on: January 20, 2015, 05:10:08 pm »
manual gets bolted to the side of the engine. there should be a filter where the inlet line bolts to the carb. you cant see it till you remove the line and its in the carb
Offline Nj1986k10
Re: No fuel
« Reply #6 on: January 20, 2015, 05:57:15 pm »
Thanks, ill try this once i fix the starter
Offline jaredts
Re: No fuel
« Reply #7 on: January 21, 2015, 09:50:29 pm »
I think you mean mechanical pump.  A manual fuel pump would get old real quick!  Make extra sure to use two wrenches when you remove the fuel line from the carb. or it will twist and ruin the line.
