Author Topic: HELPPPP!! WHERE DOES THIS BELONG TO UNDER THE DASH, PLEASE!!!  (Read 4074 times)
Offline kuhio
« on: January 20, 2015, 05:17:03 pm »
Welllll, when I was trying to install the long plastic crossover heater/ac duct to the left vent, this fell out from under the dash. Looks like it was located somewhere to the left of the steering column. Its spring loaded with a small metal contact attached. Any under dash Guru's know what this part may be and where it goes??? Its really tight for me to spot where this might have fallen out from.....
Size is about 1 inch....
Thanks in advance!!!!
« Last Edit: January 20, 2015, 05:30:22 pm by kuhio »
Offline SLUG
Re: HELPPPP!! WHERE DOES THIS BELONG TO UNDER THE DASH, PLEASE!!!
« Reply #1 on: January 20, 2015, 07:23:36 pm »
Looks like it goes to the headlight switch. I believe it is the "button" that holds the switch shaft in the switch body.
« Last Edit: January 20, 2015, 07:25:27 pm by SLUG »
« Reply #2 on: January 22, 2015, 07:30:03 pm »
Ditto
