Author Topic: 85 chevy K10 skittles build  (Read 9654 times)
Offline skittlesk10
« on: January 20, 2015, 08:44:39 pm »
 So, earlier last year I bought a 1985 chevy k10 long bed with a 6'' lift, and 35s. Bought it for 1400 from a mutual friend. I rocked this rig for the summer, and now it has to change. I bought a set of 44x18.5x16.5 gumbo monster mudders with nice tread for $450. I recently acquired a 12'' used lift kit off craigslist. So far my progress of the build is i installed the front springs and brake lines. My plan is to do the gears, motor, paint, and a dash pad  :) . Here are some pictures when i bought it till now. My paint scheme i am doing like my dads 1991 toyota. "skittles"
Offline skittlesk10
Re: 85 chevy K10 skittles build
« Reply #1 on: January 20, 2015, 08:47:03 pm »
Here is the paint scheme off my dads sbc powered toyota. Which I will be painting my truck.
Offline fitz
« Reply #2 on: January 20, 2015, 09:17:43 pm »
Sounds like a cool project.
I pulled the 12" lift and 44" swampers off my truck a few years ago.
Is this an off road only truck?
Offline skittlesk10
« Reply #3 on: January 20, 2015, 09:45:18 pm »
Im from milwaukee, and yes i plan on finishing it here in a month. Its at my grandparents house up north. My plan is to make it usable for both street and mud. Hope to have it finished by prom.  ;D
Offline skittlesk10
« Reply #4 on: January 20, 2015, 09:54:21 pm »
I need to buy the sway bar brackets, and steering link. At least it is moveable i will eventually upgrade to a crossover and danas.
Offline skittlesk10
« Reply #5 on: January 22, 2015, 07:18:53 am »
Going to be finishing up the rear this weekend. Hopefully next week i will have my rims, gears, and steering components. Just another update
Offline skittlesk10
« Reply #6 on: January 26, 2015, 07:53:08 pm »
I managed to finish up the rear end, and get the shocks in on all 4 corners. I am going to look at a set of axels dana, and a 14 bolt. Both axels have 5:38 gears installed in them. The bad news is i found a rot hole in frame by spring mount, and crack. So i am going to ix it with heavier steel, and would like to box frame in spots.
Offline LTZ C20
« Reply #7 on: January 26, 2015, 08:00:04 pm »
Based on the above pic, your going with the tire size on the front or the tire size on the back? Cuz those are some pretty big treads.
LTZ Cheyenne C20
Offline skittlesk10
« Reply #8 on: January 26, 2015, 10:29:20 pm »
All the way around are the 44s. 12" of lift all the way around as well. I need to get longer shocks unless i mount the dual shock bracket to the top side of the axel.
Offline LTZ C20
« Reply #9 on: January 27, 2015, 12:25:30 am »
So all 4 tires are the same size? The rears look like they are 1 size smaller?? Optical illusion?
LTZ Cheyenne C20
Offline skittlesk10
« Reply #10 on: January 27, 2015, 03:22:16 pm »
Illusion probably. i just have them sitting in front of the 35s to give me an idea of what it will look like.
Offline LTZ C20
« Reply #11 on: January 27, 2015, 04:25:46 pm »
Oh ok that explains it
LTZ Cheyenne C20
Offline skittlesk10
« Reply #12 on: February 17, 2015, 03:20:16 pm »
Some progress i bought a Dana 60 and 14 bolt rear both with 5:38s and locker in back.
