Author Topic: New Gears  (Read 5332 times)
Offline The_New_Guy
New Gears
« on: January 24, 2015, 11:25:28 am »
Hey guys, I'm new here so I have a 1985 chevy truck with a granny gear 4speed. I'm headed to college soon so due to circumstances I'll be taking her on a close to 2 hour drive. And the truck is for sure not geared for that. Cause 70mph is about 3,000 rpm. I was wondering what gear recommendations y'all would have. Thanks!
Offline 78BIG-TEN
Re: New Gears
« Reply #1 on: January 24, 2015, 11:36:37 am »
Depends on tire size,#.08 with 28 inch tires put my 78 at about 2600 at 70
Offline The_New_Guy
Re: New Gears
« Reply #2 on: January 24, 2015, 12:28:45 pm »
I just have stock size 16 inch tall tires
Offline 78BIG-TEN
Re: New Gears
« Reply #3 on: January 24, 2015, 03:18:34 pm »
So its a 3\4 or 1 ton.if so at that rpm probably has 4.10 in it
Re: New Gears
« Reply #4 on: January 24, 2015, 05:22:52 pm »
2 hour drive becomes 2.5 hour drive at 55 mph.  More time to enjoy the scenery and a whole lot cheaper than a gear swap.  My $.02
Offline The_New_Guy
Re: New Gears
« Reply #5 on: January 26, 2015, 02:59:14 pm »
It has 4.33's by the original parts identification in the truck. And the truck does decent running at 65mph
Re: New Gears
« Reply #6 on: January 26, 2015, 03:34:01 pm »
Interesting, never heard of that ratio.  You sure?
Re: New Gears
« Reply #7 on: January 26, 2015, 07:09:43 pm »
4.56 is the largest gear ratio you could get in 1985 and it was 3/4T or 1T only.  How did you derive at 4.33?  the ratio lower than 4.56 is 4.10.
We need more information on the truck to give a recommendation though
What axle? if it is 16's it has to be 3/4T up, so what tire size, what engine and what it the normal use?
Offline roundhouse
Re: New Gears
« Reply #8 on: January 28, 2015, 07:22:14 am »
Taller tires are always cheaper than a gear swap
Or just drive slower on your trip
Never seen 4.33
