Author Topic: Alternator Bracket  (Read 4728 times)
Offline enaberif
Alternator Bracket
« on: January 24, 2015, 08:35:16 pm »
Can someone give me some insight to what is happening here please. I know this is not a standard alternator bracket. Is this a problem with the water pump on the truck or the bracket itself?
Re: Alternator Bracket
« Reply #1 on: January 24, 2015, 09:26:01 pm »
The upper bracket is wrong but should work if the belt lines up and the bracket will tighten the belt.  If you need the right bracket I have a few extra sitting on a shelf.
Offline enaberif
« Reply #2 on: January 24, 2015, 10:04:41 pm »
Yeah everything lines up but I need to use nearly 1" of washers to tighten the alternator down. For now I'll make it work but I will be fore sure getting proper bracket.
Offline Engineer
« Reply #3 on: January 25, 2015, 06:13:48 am »
Ugh.
Yeah, you need the factory bracket in the worst way.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Magic1
« Reply #4 on: January 25, 2015, 06:26:09 am »
I had the same type bracket on mine and had trouble with the belt squealing. No matter how much I shimmed it I couldn't get it just right. Then when I was ordering an electric fan from summit I saw they had a chrome alternator bracket that bolts to the bottom of the water pump and has an adjustment on top with a heim joint on each end and a threaded sleeve to loosen or tighten the tension.  Best 25$ I've spent in a while. No more squeal or belt wandering and very simple to adjust.
Offline enaberif
« Reply #5 on: January 25, 2015, 07:23:02 pm »
So I tried an aftermarket adapter.. not a hope in heck it was going to work.. Looks like this will be the usable one for the foreseeable future until I get an oem one.
