Author Topic: Rear disk brakes from a camaro???  (Read 17503 times)
Re: Rear disk brakes from a camaro???
« Reply #15 on: February 04, 2015, 07:31:04 pm »
OK and what rotors then?
Offline swilliams
« Reply #16 on: February 04, 2015, 07:59:42 pm »
I see what you are saying. So i am back to the start. What rear disk  will work with 15" wheels and 5x5 bolt pattern. Is that what i should have ask?
Offline timthescarrd
« Reply #17 on: February 04, 2015, 08:19:39 pm »
A Jeep WJ (99-04 Grand Cherokee) should be 5x5 and fit 15" rims with discs
« Reply #18 on: February 07, 2015, 09:57:16 am »
As stated, the ones I posted use '94-'96 Impala/Caprice rotors (5x5") and '93-'97 F-body calipers which have a built in e-brake.
« Reply #19 on: February 07, 2015, 11:44:45 am »
If I recall correctly the hat of the rotor is too small for the GM truck axle flange.
Unless you have a really good reason, this isn't a mod you'll be saying WOW! so glad I did it. There's money much better spent on other upgrades and the drum braking system works great if it's in good working order.
