Author Topic: rear inner fender panels  (Read 3378 times)
Offline jg1977c20
« on: January 30, 2015, 02:00:59 am »
77 c20 long bed -  i have some rust spots on the rear wheel well ,and i am wonder if the inner fender panel will un bolt from the ,inner tub to gain access to the back side of the bedside ?
1977 c20 cheyenne camper special 8200gvw
Re: rear inner fender panels
« Reply #1 on: January 30, 2015, 05:40:55 am »
All the bed panels will unbolt except for the two welds at the base of the tailgate opening posts.
Offline jg1977c20
« Reply #2 on: January 31, 2015, 02:15:16 am »
to my surprise i tried a couple bolts that attach the inner fender to the tub and the came right out - i doubt theyve ever been touched since 1977, next will be to see if i can get the inner fender out without having to remove the tub as well - if anyone knows feel free to comment
the reason i want to get them out is i have a couple rust bubbles that poked thru so i want to see if it started on the back panel so i can remove the rust and add some protection , too bad the inner fender is their seems it causes problems cause the rest of the bed side is fine
« Last Edit: January 31, 2015, 02:18:27 am by jg1977c20 »
