Author Topic: Back Glass  (Read 5836 times)
Offline traumajunkie
Back Glass
« on: January 31, 2015, 03:05:19 pm »
HEY GUYS NOT SURE IF THIS IS THE CORRECT PLACE TO POST. I HAVE A 84 C10 THAT I BOUGHT WITH NO BACK GLASS. THERE IS NO DAMAGE TO THE EDGING AROUND THE WINDOW INCLUDING THE METAL BEED/ LIP INSIDE THE OPENING. SAFELITE AND ANOTHER LOCAL  COMPANY HAVE NOT BEEN ABLE TO PUT A BACK GLASS IN DUE TO IT BEING TO "TIGHT". THEY ARE CLAIMING BODY DAMAGE WHICH IS CRAZY. ANY THOUGHTS WOULD BE GREAT.
911 Please State Your Emergency
Offline Kren420
  • 1986 C10 Silverado
Re: Back Glass
« Reply #1 on: January 31, 2015, 03:13:03 pm »
picture please.  unless serious bend in the cab and they are correct parts it should go.... can be a jerk sometimes
Offline jg1977c20
Re: Back Glass
« Reply #2 on: January 31, 2015, 03:59:01 pm »
are you using the string method or just trying to get it in there -
1977 c20 cheyenne camper special 8200gvw
Re: Back Glass
« Reply #3 on: January 31, 2015, 04:12:24 pm »
They were using the string method, plus me and my buddy helping push on the window frame, hew as able to get the slider in but the slide window would not open due to to much pressure. I will have to get a pic mobday because its at the second shop due to trying a different gasket. Like i said minor dent in roof but no bondo,wrinkles,cracks,gaps holes or anything in the bead and channel
Offline jetmech
Re: Back Glass
« Reply #4 on: January 31, 2015, 11:00:49 pm »
Measure the glass opening when you can and I will measure one of my cabs tomorrow.
'86 Sub and '86 SWB C-10
1990 454 SS
Offline jetmech
Re: Back Glass
« Reply #5 on: February 03, 2015, 08:42:58 pm »
Opening measured 13 3/4 inches.
1990 454 SS
Re: Back Glass
« Reply #6 on: February 04, 2015, 04:25:10 pm »
Is it a factory slider and gasket and are they attempting to use the same gasket on the glass?  Depending on who made the slider it will come with a different gasket...
Re: Back Glass
« Reply #7 on: March 02, 2015, 09:15:03 pm »
Finally got the window done, and not by safelite. The gaskets they use are to thick. I went with a different company and had no issues. Thanks for the help guys
