Author Topic: Gauge Install question  (Read 4117 times)
Offline traumajunkie
« on: February 13, 2015, 02:33:56 pm »
Ok so I have looked all over the internet and this site and cant get a clear answer. I have a 1984 c10 with the straight 6 (250 4.1L). I want to install a oil and temp gauge because mine work intermittently (I have the light, no numeric gauge's). where is the oil sending unit and the temp sending unit located?All the places I have looked show a v8 of Some sort, ALSO I want to keep the auto choke/oil light.. will installing another oil gauge interfere with that ?
911 Please State Your Emergency
Offline cali6shooter
Re: Gauge Install question
« Reply #1 on: February 13, 2015, 06:26:02 pm »
I have an 80 c10 same engine the water temp sending is up front by thermostat the oil temp is back by the fire wall on the side of the block right below valve cover ur  second question can't answer would love to know it though I need an oil and and tranny temp sensor I oil have water and I would love to the the temp of both which is cheaper buying them individually or in a package don't have much to spend
« Reply #2 on: February 13, 2015, 08:42:54 pm »
Thanks for the reply, I am a little wary messing with the choke because i was told you cant have 2 of the same thing..
« Reply #3 on: February 19, 2015, 10:34:27 pm »
The oil sending unit should be above the starter on an I6.  The temp sensor should be in the head.  Just T off of the oil.
