Author Topic: Is there something missing ?? And is that really silicone?  (Read 7812 times)
Offline traumajunkie
« on: February 13, 2015, 04:58:51 pm »
here is my 84 c10 my main question is... what the heck is silicone doing there and what is it in ??? second I feel the heater hoses should be going into something before the firewall?? like a box of some sort.
« Last Edit: February 13, 2015, 08:46:30 pm by traumajunkie »
911 Please State Your Emergency
Offline cali6shooter
Re: Is there something missing ?? And is that really silicone?
« Reply #1 on: February 13, 2015, 06:16:15 pm »
What year is this truck i
Can't see the silicone but if it helps you any I have a 1980 c10. With. 4.1 250 straight 6 and both my hoses go directly into the firewall unless mine is wrong to
« Reply #2 on: February 13, 2015, 06:18:15 pm »
What's the second pic is that a broken intake bolt that got broken
« Reply #3 on: February 13, 2015, 06:20:17 pm »
First and foremost my main question is... what the heck is silicone doing there and whats it in ??? second I feel the heater hoses should be going into something before the firewall??
Question is ur  oil filler cap. Supposed to be up front mine is in back wonder if mine needs to be flipped
Offline timthescarrd
« Reply #4 on: February 13, 2015, 06:54:25 pm »
First pic, heater hoses, on a non-AC truck the heater hoses attach directly to the heater core which is inside the dash, so that looks correct.
Second pic, silicon, I'm not familiar enough with the straight-6's to be any help here, Looks like there was some type of sensor or connector on the intake manifold and someone sealed it with some RTV cause they didn't want to mess with it, the only thing I could think of would be if it's a vacuum port for vacuum assist brakes, which your truck doesn't have.  If the truck runs properly, i would get a solid plug for it so it doesn't suck the RTV into the intake and cause a vacuum leak.
« Reply #5 on: February 13, 2015, 08:45:39 pm »
I have looked in the manual and cant seam to find anything.. I dont wanted it to be jerry rigged that is for sure. it seams to run fine with the exception of a oil leak but that is a different story.
« Reply #6 on: February 13, 2015, 09:22:55 pm »
also is my motor what they call the integrated head ? I cannot find anything electrically that plugs into the intake manifold and its not showing on the emissions as well...
« Reply #7 on: February 13, 2015, 10:39:36 pm »
Yes it is the integrated head they did Chevy did it on the 235 250 292 the intake and head are all one piece and my engine has no sensor anywhere near there think a bolt broke off in the spot and they thought the leak was coming from there so they silly coned it
« Reply #8 on: February 13, 2015, 10:46:41 pm »
All vacuum lines
« Reply #9 on: February 14, 2015, 03:38:09 am »
I have that on my 84, it is an AIR tube connection.  I am having a hard time finding a replacement because one of mine is leaking
« Reply #10 on: February 14, 2015, 05:55:51 pm »
Wait which problem you talking about zieg
« Reply #11 on: February 14, 2015, 10:57:54 pm »
so its just a standard tube that goes there? Where does it go from there?
« Reply #12 on: February 19, 2015, 09:41:55 pm »
That pipe plugged off is part of the PAIR - Pulse Air Injection Reaction System.  It comes from the A.I.R pump on the front of the motor IF it is still there.  It is emmisions equipment.
If you go here and search for Air Injection Reaction you will find the description of it: http://www.73-87chevytrucks.com/techinfo/7387CKMans//Service/X8432_1984_GMC_Light_Duty_Trucks_Service_Manual.pdf
