Author Topic: Radio hole too big  (Read 6826 times)
Offline Nj1986k10
Radio hole too big
« on: February 18, 2015, 07:25:32 pm »
The previous owner modified the bezel and it is slightly too big for my bew headunit. Can i use diamond plate to cover the hole than cut an opening?
Offline LTZ C20
Re: Radio hole too big
« Reply #1 on: February 18, 2015, 07:43:42 pm »
I don't see why not. Basically all your doing is making a new mounting location with the proper size cut out. If it's gonna go on top of the bezel you can use something nice like diamond plate or one of the aluminum inserts that go in the door panels. If it's gonna go behind the bezel on the steel dash frame, use a clean piece of mild steel or anything that's not a piece of crap.
LTZ Cheyenne C20
« Reply #2 on: February 18, 2015, 10:54:37 pm »
like said yes, but imo i wouldnt. just for the simple reason if you put a shinny piece of aluminum its like a fishing lure to rednecks and it will catch every ones eye. to me it would be a eye sore i would put a piece of metal spray painted black or even the diamond plate painted black so it doesnt stick out so bad
Offline LTZ C20
« Reply #3 on: February 19, 2015, 12:52:27 am »
Not a bad idea either.
LTZ Cheyenne C20
Offline Nj1986k10
« Reply #4 on: February 19, 2015, 05:57:54 am »
Im just trying to use sometbing so i dont have to buy a new bezel. Really doesnt matter what the material is, just diamond plate popped in my mind first
« Reply #5 on: February 19, 2015, 06:03:21 am »
also with dia plate the radio wont sit flush
Offline Nj1986k10
« Reply #6 on: February 19, 2015, 06:28:21 am »
True. Never thought of that. I got wire it too cause all my wires except pwr and antenna were ripped out
Offline LTZ C20
« Reply #7 on: February 19, 2015, 09:49:46 am »
If you go to the junk yard, try to find a 76 I think or maybe 77-80 chevy or gmc truck with door panels, the high trim door panels have a piece brushed aluminum in them. They are easy to get out and are big enough you should be able to make 2 plates with 1 panel. Then you get a factory piece, made from factory part that looks like it might belong around the radio.
Just an idea, and it's flat, not bumpy like diamond plate so it should sit flat.
LTZ Cheyenne C20
