Author Topic: Gauge Power  (Read 3198 times)
Offline traumajunkie
Gauge Power
« on: February 19, 2015, 02:43:02 pm »
Quick question, I am supplying power to my tach via the acc on the fuse box, I am adding new gauges and wanted to know if I can have all the power going to the acc on the fuse box, so  3 power wires spliced to 1. Thanks
911 Please State Your Emergency
Re: Gauge Power
« Reply #1 on: February 19, 2015, 07:23:26 pm »
Sure you can.  What kind of load are you putting on it though?  Just lights? or?
Re: Gauge Power
« Reply #2 on: February 19, 2015, 07:32:54 pm »
Going to the instrument fuse will be the lights from one sunpro super tach and then the 3 sunpro mini gauges(oil,water and volt) as for power i will have the voltmeter and tach going to the acc fuse. As of now i have them plugged in to the fuse box with the fuse holding the wire in. I plan to splice and solder to make in cleaner if its not to much of a load
