Author Topic: Mec. Fuel pump block off with npt fittings  (Read 3207 times)
Offline K1nglou
« on: February 19, 2015, 08:50:41 pm »
Hello I am getting rid of my mechanical fuel pump and saw these block off plates with pipe fittings in them. Any one have an idea why the make these? Thanks
http://m.summitracing.com/parts/mor-65398
85 Silverado k10 4x4 6.2D 700r4
Re: Mec. Fuel pump block off with npt fittings
« Reply #1 on: February 19, 2015, 09:45:00 pm »
Notes: Includes 12 AN fitting, which can be used to hook up vacuum pump and gauge or as a drainback location.
If you have a standard SBC, use this:
http://www.summitracing.com/parts/sum-401030/overview/
Offline K1nglou
« Reply #2 on: February 20, 2015, 04:42:32 am »
Ya I saw that I guess I was just curious for more information like is this a good drain back point for a turbo? Why would you hook a vacuum pump to your crankcase? Is it an alternative to hooking your PCV to the intake? PS I cannot wait for the gauge pods next month!
« Reply #3 on: February 20, 2015, 04:54:07 pm »
Yes it is a excellent spot for an oil drain back location.
Offline Engineer
« Reply #4 on: February 21, 2015, 08:49:34 am »
Vacuum pumps are for all out racing. When you need that extra "little bit".
Cost vs. benefit. Is the negative pressure under the pistons and the lightly better ring seal worth the money and the parasitic drag on the crankshaft?
« Last Edit: February 21, 2015, 08:53:21 am by Engineer »
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
