Author Topic: Distorted speaker  (Read 4758 times)
Offline Nj1986k10
Distorted speaker
« on: February 23, 2015, 05:47:34 am »
I just wired a new headunit and dash speaker in my truck. The speaker sounds like garbage. Could the problem be the small wire that came with it? Poor ground? Im also gonna be adding cab corner speakers
Re: Distorted speaker
« Reply #1 on: February 23, 2015, 10:04:26 am »
are you still using the stock speakers?
« Last Edit: February 23, 2015, 10:22:25 am by Irish_Alley »
Offline jaredts
« Reply #3 on: February 23, 2015, 09:18:05 pm »
You have a new head unit and dash speaker, but the speaker sounds bad, right?  You wired the speaker with the wire that came with it?  Can you give model numbers for the speaker and head?
Offline FlatBlack77
« Reply #4 on: February 23, 2015, 10:33:56 pm »
you have a new style(four channel) head unit and you wired it to a single speaker correct?
Offline Nj1986k10
« Reply #5 on: February 24, 2015, 05:59:53 am »
Got it fixed. I just needed an antenna cable exatension. I didnt have it plugged in since i was only using the aux cord
