Author Topic: Exhaust Backfire  (Read 3040 times)
Offline 1986GMCSierra
Exhaust Backfire
« on: February 26, 2015, 10:36:39 pm »
I have a 1986 305 GMC C1500 i have the rochester 4bbl carb and i have a backfire problem..... for now the exhaust is set up like.. stock headers to catylitic converter to pipe then out, so pretty much straight piped..... i took it all apart and ensured there are no leaks... i cant seem to track down the backfire problem.. the idle is also higher than normal but that is juat my judgement by sound because i dont have a tachometer...
Offline rich weyand
Re: Exhaust Backfire
« Reply #1 on: February 26, 2015, 11:28:29 pm »
I take it you mean after-fire -- out the exhaust -- and not backfire -- back through the carburetor.
I got afterfires and loss of power in my truck when the distributor, which had not been properly clamped down, moved retarded.  I checked, and I was at 4* AFTER top dead center.
« Reply #2 on: February 28, 2015, 07:38:42 pm »
yes i mean afterfires.... i will take a closer look
