Author Topic: Dexcool problems  (Read 13885 times)
Offline 78BIG-TEN
Re: Dexcool problems
« Reply #15 on: March 02, 2015, 08:55:27 am »
Back in the day I read an article in a trade magazine where Ford was trying to develop a phenolic engine.I was told that by an old radiator shop that it was cause by voltage in the coolant.Every fleet that I worked with checked the coolant with a volt meter,if it had any a flush was done
Offline roundhouse
« Reply #16 on: March 02, 2015, 10:46:41 am »
I've heard the circulating water can build up a small static electricity charge
The 7.3 diesels have issues with cavitation
Around the cylinders
The diesel explosion shakes the water away from the cylinder for a millisecond
When the water rushes back around the cylinder it causes a tiny microscopic bit of erosion of the metal
After many years it can eat a hole thru the metal
There is an additive that was developed to address this issue and it actually works
So before you buy a used 7.3 bring a test strip and see if they additive is present in the coolant
Offline LTZ C20
« Reply #17 on: March 02, 2015, 02:25:56 pm »
Where there's a cool piece of info I didn't know! Thanks Roundhouse.
LTZ Cheyenne C20
« Reply #18 on: March 03, 2015, 06:34:24 am »
Any of my customers that still have Dex Cool in their system I tell them they need to flush it, & go back to green coolant. Have seen dozens of issues with Dex Cool doing just what the pics show.
