Author Topic: th350 transmission  (Read 3007 times)
Offline nathan.leitch.7
th350 transmission
« on: February 28, 2015, 05:39:34 pm »
i have a Th350 transmission it will go into drive fine but while in drive it hits 2000rpm and should shift to second but feels like it shifts into reverse making it bog down until u hit low enough rpm and will some times make the tires lock up
Offline FlatBlack77
Re: th350 transmission
« Reply #1 on: February 28, 2015, 05:59:15 pm »
that doest sound good at all
did you just install this transmission or service it in any way? or did this just start happening out of the blue
« Reply #2 on: February 28, 2015, 07:48:21 pm »
I bought the truck in October, didnt do anything to the transmission, I've checked the fluid it's good, it just happened out of the blue, my trucks a 1982 gmc Sierra and has a 350 in it
Offline NCali
« Reply #3 on: March 01, 2015, 05:41:38 pm »
That transmission has a governor under a cover by the tail shaft. There is a gear on that gov that gets torn up and the governor stops turning. you can probably go to a wrecking yard and pull one out of another th 350
Black Labs Matter
