Author Topic: 1986 C10 Speedhut Gauge install  (Read 18657 times)
Offline swilliams
« on: March 01, 2015, 07:11:47 pm »
I am starting on a gauge upgrade for my truck. I have decided to go with Speedhut gauges because i think i can do the install them without having to cut or splice into the harness using the stock printed circuit. I will have to see how it goes.
This is what i have now.
4" GPS speedo it has several features like 1/4 mile speed, top speed and others.
Small gauges oil,water and volts are 2 1/16 fuel is 3 3/8 they do not offer a 4" fuel gauge.
My original gauges had a clock i will replace it with a wideband AFR gauge 2 1/16 also.
I bought this donor cluster off ebay for $50 bucks all but the speedo works. I am going to keep my original cluster for future projects. I will post pics as i go let me know what you think.
« Last Edit: March 24, 2015, 03:02:36 pm by swilliams »
Offline swilliams
Re: 1986 C10 Speedhut Gauge install
« Reply #1 on: March 10, 2015, 11:32:44 pm »
This is how i will mount the gauges.
I still have to do the AFR gauge. The fuel gauge i mounted low to cover the hole from the lights that were there.
I had to do some trimming.
« Last Edit: March 24, 2015, 03:15:35 pm by swilliams »
« Reply #2 on: March 11, 2015, 12:36:22 am »
looking nice
Offline audrima
« Reply #3 on: March 11, 2015, 04:33:50 pm »
Awesome!
Offline FlatBlack77
« Reply #4 on: March 11, 2015, 10:15:50 pm »
looks good dude in for more pics
Offline swilliams
« Reply #5 on: March 11, 2015, 11:55:46 pm »
Thanks I should be off this weekend and do some more
Offline swilliams
« Reply #6 on: March 24, 2015, 01:57:15 am »
I did not have a lot left to do. I had an issue with the fuel gauge wiring it ended up that it had to share the same ground as the sending unit. Other than that real simple. The beat thing is i did not have to cut or splice any of the original wiring.
You can click on the 2 pics for the video. they are also links to all the pics of this install. I am unable to resize them SORRY
« Last Edit: March 24, 2015, 03:22:25 pm by swilliams »
« Reply #7 on: March 24, 2015, 12:25:22 pm »
I can't see some of the pics?  Is it just me?
Offline LTZ C20
« Reply #8 on: March 24, 2015, 01:42:54 pm »
Not just you. I can't see them either. They are tiny and fuzzy.
LTZ Cheyenne C20
« Reply #9 on: March 24, 2015, 02:28:31 pm »
he moved them for some reason
Offline swilliams
« Reply #10 on: March 24, 2015, 03:23:51 pm »
Sorry i fixed it now.
