Author Topic: fuel gauge way past full  (Read 11878 times)
Offline ian75c10
    • Art Dir / Designer Ian Goolsby
« on: March 02, 2015, 11:42:02 am »
Hey guys so my fuel gauge has always read way past full when I fill the tank. It seemed as low as I could run the truck would be right when it hits E on the dot it would run out. Well the other day I ran out of gas at an 8th of a tank. Or even more that that according to the gauge. It way right between a quarter tank and empty when it ran out. Is there a quick fix in the dash that I can reset the gauge? I dont have any glass/plastic on my cluster over the gauges so I can actually touch the needle. I tried spinning it counter clockwise to read more accurate but it just goes back being too advanced. Is this something I need to get into the tank for? I have a carter 4070 fuel pump mounted under the tank on the frame rail. does this pump need more gas pressure from gravity because its more of a pusher than a puller? Thanks for the info in advance.
Re: fuel gauge way past full
« Reply #1 on: March 02, 2015, 12:14:40 pm »
Full being at 3:00 is usually a bad ground but still having it go down might mean a resistor going bad on the back of the fuel gauge.
Offline ian75c10
« Reply #2 on: March 02, 2015, 12:17:34 pm »
Thanks, is the resistor something the autoparts might have and is it easily replaceable?
« Reply #3 on: March 02, 2015, 12:22:04 pm »
Don't know, search the forum here I know it has been discussed in a thread not to long ago
Offline rich weyand
« Reply #4 on: March 02, 2015, 01:19:36 pm »
Usually the gauge will read 1/4 at full and go down from there if the resistor is broken.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=27370.msg227687#msg227687
Offline ian75c10
« Reply #5 on: March 02, 2015, 05:18:07 pm »
I just took the whole cluster apart and cleaned the contact point for the fuel gauge, they did look old. I couldnt find the ground wire for not only the fuel gauge but the entire cluster. Put everything back together and still reading same fuel level.
Offline 76K20
« Reply #6 on: March 03, 2015, 02:05:33 pm »
I think they mean the ground at the fuel tank.
Offline enaberif
« Reply #7 on: March 03, 2015, 02:38:49 pm »
Yes it gets corroded or falls apart. Unfortunately you gotta drop the tanks to get to it most times.
Offline 76K20
« Reply #8 on: March 03, 2015, 02:46:25 pm »
Or remove the bed
Offline FlatBlack77
« Reply #9 on: March 03, 2015, 10:33:20 pm »
my 79 does almost the exact same thing.
a full tank is like 2-2:30 on the gauge and empty is 1/8th.
and on my 77, full is full and empty is 1/8th. learned that the hard way.
