Author Topic: Factory Tach question  (Read 20725 times)
Offline 76K20
« on: March 03, 2015, 02:10:55 pm »
Got a 76 K2o with a factory tach in dash.  Go power at the tach on the pink(hot) wire and got a good ground but can't get a reading on the brown wire coming from the distributor with a 12 volt test light.  Do I need to use a meter?  what setting if so?  Also there is a resistor in the brown wire how can I test this.   Thanks, Alan
Offline LTZ C20
Re: Factory Tach question
« Reply #1 on: March 03, 2015, 02:23:12 pm »
The wire from the distributor will only have power comming from it if the engine is running I believe. Not sure what to what setting a meter needs to be on.
Are you trying to diagnose a problem? Tach not working?
LTZ Cheyenne C20
Offline 76K20
« Reply #2 on: March 03, 2015, 02:30:23 pm »
Tach is not working.  I tried it with the engine running.  I'd like to make an effort to get the factory tach working before going to an aftermarket.
« Last Edit: March 03, 2015, 02:33:38 pm by 76K20 »
Offline LTZ C20
« Reply #3 on: March 03, 2015, 02:34:52 pm »
Ok. Look in the tech section, under your year, the service manual might have a section for diagnostics for the cluster.
I think you can run a wire from the distributor to the back of the tach, if it works with a temporary  wire then the factory wire is probably broken somewhere inside.
If it still doesn't work, test the lead directly at the distributor to make sure the distributor has outgoing signal.
Some more experienced members will hopefully chime in.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #4 on: March 03, 2015, 02:36:08 pm »
Oh and the printed circuit board on the back of the cluster bucket should be clean and unbroken and the harness should be clean and making good contact.
LTZ Cheyenne C20
Offline 76K20
« Reply #5 on: March 03, 2015, 02:45:26 pm »
I thought about running a temporary wire but I'm not sure what the resistor does.   Thanks for the help LTZ
Offline LTZ C20
« Reply #6 on: March 03, 2015, 07:35:50 pm »
True. If another member chimes in, they might know about the resistor, then you could just put the right resistor on a wire and try that.
LTZ Cheyenne C20
Offline timthescarrd
« Reply #7 on: March 03, 2015, 09:05:05 pm »
when you talking about resistor, is it a little metal canister with a wire leading in and out on the firewall like below?  I've heard these called filters, condensers, capacitors... but what they're there for is to filter out RF noise that can cause the tach to jump around.
Offline LTZ C20
« Reply #8 on: March 03, 2015, 11:29:47 pm »
So there you go. Thanks to timthescarrd, you should be able to use a temporary wire without any resistors or that kinda stuff. Just for testing to see if the factory wire has gone bad.
LTZ Cheyenne C20
« Reply #9 on: March 04, 2015, 01:04:04 am »
hope this helps but the "tach" signal off the distributor is a "common" wire
note how when you hook a tach up to a coil you use the neg post of the coil
Offline 76K20
« Reply #10 on: March 04, 2015, 05:31:23 am »
That's exactly it. Thank you
Offline 76K20
« Reply #11 on: March 04, 2015, 05:41:14 am »
I  know they were a common wire on aftermarket tachs that's why I was leery  about using a common on the factory tach not after seeing the filter on mine.
Offline LTZ C20
« Reply #12 on: March 05, 2015, 01:05:09 pm »
You should be ok for testing. If you want to get a new wiring harness for the the tach, I believe that some of the major resto parts companies sells that harness pictured above.
I would first determine if that's the problem or not tho.
LTZ Cheyenne C20
Offline 76K20
« Reply #13 on: March 05, 2015, 05:21:01 pm »
Yea soon as I can get my truck back in the garage I'm going to run a new wire.  Got the garage filled up with guns to blue right now.
Offline LTZ C20
« Reply #14 on: March 05, 2015, 06:47:27 pm »
Cool. Good luck, let us know what you find when you run the new wire. Have fun with your guns too, I know I do.
LTZ Cheyenne C20
