Author Topic: 79 k10 translation problem  (Read 2966 times)
Offline gutts
« on: March 05, 2015, 08:10:37 pm »
Hello
  A friend has a 79 k-10 ,  350 ci , automatic trans . I do not know if it is a turbo 350, or 400. He is having problems , it doesn't go into reverse . Is it common for reverse to go , or could it be a linkage type problem ?
Re: 79 k10 translation problem
« Reply #1 on: March 05, 2015, 11:03:01 pm »
reverse can go by itself and it not effect forward gears. could be a linkage problem
search ebay for "Chevy GM column shifter linkage bushing sleeve"
BUT i doubt its your problem and i dont want you to buy something if your not sure if it is your problem. most times the shifter will have to be in neutral for the transmission to be in drive
