Author Topic: Headlight issue  (Read 3415 times)
Offline CarlBengston
Headlight issue
« on: March 06, 2015, 04:37:27 pm »
Hi guys, just bought a 1983 k10. My headlights and tail lights don't work when I pull the switch. I have break lights/turn signals/hazards. I have power at the yellow wire that comes out of the headlight switch but I don't have power at the dimmer switch. Does the yellow wire run through the fuse panel? I looked at the wiring diagram and it doesn't look like it. Thanks in advance
Offline srozell
    • My 1980 Chevy
Re: Headlight issue
« Reply #1 on: March 10, 2015, 01:45:31 am »
I had lots of corrosion at my dimmer switch, creating a grounding issue,  which caused my headlights/taillights not to work. This seems pretty common with these trucks.
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
