Author Topic: Ball joints for a 1985 Chevy k10  (Read 22808 times)
Offline Decker1024
« on: March 11, 2015, 02:02:14 pm »
I need some new ball joints but the mechanics around my area want a ridiculous amount of money to install them, was think of doing it myself but not sure what I need, was hoping someone could help me out, I'm 17 and absolutely love old Chevy trucks, I rebuilt the top end of my engine myself and want to learn more about these old Chevys, anything helps, thanks in advance
Offline Engineer
Re: Ball joints for a 1985 Chevy k10
« Reply #1 on: March 11, 2015, 04:57:28 pm »
There is a procedure that needs to be followed.
Special tools needed are the 4-prong spindle nut socket. A ball joint fork. There is a small spanner socket that you will need to preload the sleeve on the top balljoint stud.
Standard tools needed are needle nose pliers. Hex sockets for the tie rod nuts, upper ball joint lower ball joint. Snap ring pliers. Allen wrench for the lockout cap. And so on......
You'll also need access to a hydraulic press. Beating the old ball joints out is acceptable but the new ones need to be pressed in.
There is also a big c-clamp looking thing with a hole in it that is for pressing ball joints in. This can be used in lieu of the hydraulic press.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Kren420
  • 1986 C10 Silverado
« Reply #2 on: March 11, 2015, 06:16:47 pm »
http://www.delbridge.net/balljoints
I found this to be a useful link
« Reply #3 on: March 11, 2015, 07:47:45 pm »
What is rediculous money?
Offline Decker1024
« Reply #4 on: March 11, 2015, 08:45:23 pm »
Thanks for the help guys, really appreciate it, and they're asking around 3-400 per side, figured I could do it myself for cheaper as I already have most of the tools
Offline FlatBlack77
« Reply #5 on: March 11, 2015, 10:14:20 pm »
thats not really all that much if you think about labor rate being $50-80 bucks an hour plus parts. I am NOT saying thats cheap but for a shop doing everything id say its resonable.
But its not the way to go. take your time and dont cut corners and you can do it yourself for the price of parts and probably the rental fee of a ball joint press kit like Engineer mentioned.
I did my 79's balljoints with the help of my stepdad in about 12 hours with a few setbacks and small issues like having to run to town for parts. not the fasted time in the world but it  was our first time with on a squarebody balljoint job
Offline Decker1024
« Reply #6 on: March 11, 2015, 10:21:37 pm »
True, I just rather learn myself for future reference. Come March 20th when I get paid and have some time off I'll update you guys on how it goes, thanks for the help guys!
« Reply #7 on: March 11, 2015, 11:07:11 pm »
only problem thats 2wd. a 4wd is funner
« Reply #8 on: March 11, 2015, 11:09:40 pm »
http://www.chuckschevytruckpages.com/chevy_truck_4wd_front_axle_ball_joint_replacement.html
all the times i taken mine apart i wouldnt think it would be that much But you do have to pretty much strip the axle down
« Reply #9 on: March 11, 2015, 11:22:37 pm »
i cant seam to find a write up on a 4x4 ball joint change that we have. if you dont mind take pictures and do a write up and we will put it in a good place
Offline Decker1024
« Reply #10 on: March 11, 2015, 11:36:32 pm »
Thanks for the input, and will do!
« Reply #11 on: March 12, 2015, 12:40:37 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=30551.0 sorry just found one. knew we had something but it was so long ago i forgot how he labeled it. moved it to the Tech section so it wont be lost again.
also if you dont want to you dont have to remove the steering arm. it does make it easier but its not required
« Last Edit: March 15, 2015, 02:53:42 pm by Captkaos »
Offline Engineer
« Reply #12 on: March 12, 2015, 05:54:22 am »
Don't skimp out on anything. While you are in there inspect, and replace anything that doesn't pass "the test"
Wheel bearings and races. Spindle bearings. Spindle seals. Axle u-joints.
At the least you'll want to repack your wheel bearings so buy new wheel (hub) seals to start.
Offline roundhouse
« Reply #13 on: March 12, 2015, 06:29:21 am »
Have fun finding ball joints that are no made in china
Make sure you ask and check the box.   Otherwise that's exactly what you're gonna get
I wound tapping them back in with a properly sized socket a hammer and a chunk of wood
Offline Kren420
« Reply #14 on: March 12, 2015, 08:21:52 am »
Doh!  Big fail on my part lol
