Speedo off 10mph...
Topic: Speedo off 10mph... (Read 6331 times)
N8thegr8
Speedo off 10mph...
March 12, 2015, 01:43:22 pm »
I have an 80 C20 and I'm 10mph off at hwy speed. I have 235/85 R16s on it. Why am I so off? Thanks!
N8thegr8
Re: Speedo off 10mph...
March 12, 2015, 01:45:37 pm »
Would putting 15s on it fix my problem? I don't know if I can even find 8lug 15s
timthescarrd
March 12, 2015, 03:33:14 pm »
Speedometer is driven by a set of gears, one on the tailshaft of the transmission and one where the cable goes into the transmission. the number of teeth on each gear is changed to keep the speedometer at the right speed. 235/85/R16 tires should be around 31.75" tall, the height of the tires and the gear ratio (rear end and transmission) determines speed, so if either of these have changed from factory, the speedometer will be off by some percentage at all times.
Here is a calculator and some info on drive gears
http://www.tciauto.com/tc/speedometer-gear-calculator/
Stewart G Griffin
March 12, 2015, 08:48:34 pm »
Can you check your SPID sticker to see if these were the original sized tires that came with the truck from the factory?
March 12, 2015, 11:37:44 pm »
15" rims wont make a difference.
Last Edit: March 13, 2015, 06:30:34 am by Irish_Alley
roundhouse
March 13, 2015, 06:17:53 am »
Someone has changed the axle gears or the speedo gear in the transmission
The speedo gear is easy to change
N8thegr8
March 14, 2015, 04:21:04 pm »
Any suggestions on a speedo gear? It's a 14 bolt rear end.
enaberif
March 14, 2015, 04:47:12 pm »
Quote from: N8thegr8 on March 14, 2015, 04:21:04 pm
Use the calculator to figure it out.
March 15, 2015, 01:12:48 am »
Made this up to help
roundhouse
March 15, 2015, 10:32:18 am »
Gear ratio ?
Tire size ?
March 15, 2015, 12:53:49 pm »
This gives a good overview of the drive and driven gears...
http://73-87.com/7387garage/drivetrain/speedo.htm
Speedo off 10mph...
