Author Topic: Best k30 1 ton 6 inch lift springs  (Read 17138 times)
Offline Coleman64
  • Junior
« on: March 15, 2015, 11:38:33 pm »
Hey all I'm planing on buying a '90 gmc 3500 crewcab 6.2l diesel with a factory dealer installed turbo with a four speed motor runs great the biggest problem I have with it is the lift. The current owner went and put a 10 inch lift in the front and a 6 inch lift in the back. Guess that's just what the guy had at the time but he modified the hangars too so in the back it's more like 8 inches of lift so I plan on undoing all of what he has done in the back and buy new front 6 inch springs. My question is what are the best riding/ softest riding springs I can get separate from the rears or kit for the best value.
1990 CREW CAB  Sierra 3500 6.2 Detroit diesel 4sp 4x4 on 37s
1977 k20 sbc350/400 longbed 4x4
1974 Camaro street beast 350/350 1973 body conversion
1997 trans am ws6
1937 dodge pickup cab/bed rat rod dragster tubbed w/ 454/400
Offline illinoisk30
Re: Best k30 1 ton 6 inch lift springs
« Reply #1 on: March 16, 2015, 06:41:09 pm »
I have a 4" Skyjacker all spring lift on two of my K30's and I am very happy with the ride. I have tried Rough Country but they ride like the name states, very stiff. The smallest dips and bumps in the road felt like speed bumps. I am very pleased with the Skyjacker ride and performance though I do not do much off road. I don't know if the 6" would be as soft but would not hesitate to try. Just my opinion. Have fun.
1977 Chevy K30 DRW 400 TH400
1978 GMC K35 SRW 454 TH400
1979 GMC K35 SRW 400 TH400
1980 Chevy K30 SRW 350 SM465
Offline 87max
« Reply #2 on: March 16, 2015, 07:57:59 pm »
I second ,skyjacker softride .
88 R30 lb7 transplant in progress
04 E350 6.0 studded & tuned work van
98 Taurus beater
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #3 on: March 16, 2015, 08:12:28 pm »
Skyjacker x3 also make sure all bushings and suspension bolts are lubed and not seized it's critical to good articulation.
Offline Engineer
« Reply #4 on: March 16, 2015, 09:42:11 pm »
Skyjacker is the answer. Now what was the question?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #5 on: March 17, 2015, 06:55:24 am »
when i lift my crew im going skyjacker. i tried rough country and like stated it is a rough ride. when i was younger not so bad but now im willing to pay for a softer ride lol.
where did you guys get your lifts from?
what about the king pin deal?
did you use blocks for the rear?
Offline 87max
« Reply #6 on: March 17, 2015, 10:19:42 pm »
Got mine from summit. Didn't get rears yet just wanted to confirm height as I converted from 2wd. Gonna skip blocks this time & go all spring.
98 Taurus beater
« Reply #7 on: March 18, 2015, 02:53:40 am »
what do you do about the king pin?
Offline ehjorten
« Reply #8 on: March 18, 2015, 11:52:02 am »
BDS is another good place to source your lift kit from.
-Erik-
Offline 87max
« Reply #9 on: March 18, 2015, 06:56:44 pm »
I'm not certain what about the kingpin is of concern?
98 Taurus beater
« Reply #10 on: March 18, 2015, 10:52:45 pm »
when you lift a k20 the steering arm has to be changed to make up for the lift. so im assuming with a dana 60 you have to do something with the steering
Offline 87max
« Reply #11 on: March 19, 2015, 12:37:37 pm »
ahh bump steer, I got used to it with a 4" lift on the old truck wasn't that bad. However on this one I got a dropped pitman. Also draglinks are available with offsets in them. Or I have heard crossover is really the way to go. Back in the day guys used to get the steering arm cherry red & jack up the truck under them to bend them lol.
98 Taurus beater
Offline Coleman64
  • Junior
« Reply #12 on: March 28, 2015, 06:00:38 pm »
Hey new update just got the truck and found out that the rear springs are totally different springs than the basic k30 they are 52 not 56 inch long the guy I bought it from moved the hangars down and forward. I'm left with either moving them back and down and getting the right springs or getting longer shackles to achive the height that I want. Anybody know where I can buy a set of new 2 inch longer rear shackles?
« Last Edit: March 28, 2015, 11:43:00 pm by Coleman64 »
1997 trans am ws6
