Author Topic: Front of rear leaf spring hangers  (Read 19605 times)
Offline Oldsmolet
« on: March 18, 2015, 06:31:21 am »
I have a 85 with 77 body crew cab 4wd 1/2 ton.  It's kind of a mix. Lol. Anyway I need leaf spring hangers for the front of the rear leaf springs.  Can't find them anywhere? Any ideas?
Re: Front of rear leaf spring hangers
« Reply #1 on: March 18, 2015, 02:01:12 pm »
1/2T with a crew cab body, as in a Long bed 4wd 1/2T frame?    A salvage yard is an option and they would be cheap.
Offline Oldsmolet
« Reply #2 on: March 18, 2015, 08:50:36 pm »
Started life as a 2wd diesel 1 ton.  Searched my local yards. All I found also rusted through.
« Reply #3 on: March 19, 2015, 12:06:47 am »
so you are sitting on a 1 ton frame with ½ ton axles?
Offline Oldsmolet
« Reply #4 on: March 19, 2015, 12:20:41 am »
It was.  I didn't build the truck originally.   I bought a 14 bolt full floater and a Dana 44 today to swap in.  Not going to see much gnarly off road so they should do me fine
« Reply #5 on: March 19, 2015, 12:23:54 am »
the springs will work no matter what size. they all use the same widths some use different lengths but if all your swapping is the axles then you dont have to worry about anything
Offline Oldsmolet
« Reply #6 on: March 19, 2015, 12:25:51 am »
If you think 1/2 axles were bad you should see the rest.  It's lifted on 38s with half ton axles.   And they made their own springs out of whatever springs they found.  So not one spring pack is the same.  I don't know what they were thinking. Spent big money certain places then rigged it other places.
Offline Oldsmolet
« Reply #7 on: March 19, 2015, 12:28:11 am »
I know they are the same. That isn't the concern with mine.  My concern is they are like Swiss cheese and now with real lift the 2wd hangers make the back end almost 2 inches shorter cause I didn't notice.
« Reply #8 on: March 19, 2015, 02:13:56 am »
ok i gotcha. my buddy is building his crew cab kind of the same as how yours started a 2wd. he made his own front hangars and has some box tubing running between them as a cross member. i know i took a picture before but it was a while ago
« Last Edit: March 19, 2015, 02:18:19 am by Irish_Alley »
« Reply #9 on: March 19, 2015, 02:20:26 am »
you kind kind of see it here
90 crew Cummins 10 speed
Offline Oldsmolet
« Reply #10 on: March 19, 2015, 03:16:36 am »
Front of the REAR leaf springs.  Lol.  My fronts all good.
« Reply #11 on: March 19, 2015, 03:33:52 am »
wow totally missed that sorry lol. but theres no such thing as 2wd hangers for the front cause 2wd will have coil springs. think hangars are for the front style while shackles are the rear. you can buy aftermarket shackles with a couple different holes so you can lift the truck also a parts stores.
OR
http://www.offroaddesign.com/catalog/hdshackles.htm
Offline Oldsmolet
« Reply #12 on: March 19, 2015, 07:50:23 am »
Still don't think you get what I'm saying Irish.   The springs for the rear end! There's a shackle in the back of the spring and a hanger in the front of the spring.  All my hangers were rusted.  I did a shackle flip to fix the back ones and get lift.  The FRONT hanger for the REAR leaf spring I still need the hangers.
Offline Jason S
« Reply #13 on: March 19, 2015, 09:11:54 am »
If I remember correctly, there were 2wd and 4wd versions of the front of rear spring hanger.
This one is listed on eBay right now...
http://www.ebay.com/itm/Blazer-Rear-Leaf-Spring-Hanger-Bracket-Chevy-GMC-Jimmy-Suburban-OEM-73-80-91-77-/400865743433?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d5575d249&vxp=mtr
You may also be able to adapt a later model spring hanger, as long as the spring widths match the hanger. If nothing else, a replacement hanger could be fabricated.
Offline roundhouse
« Reply #14 on: March 19, 2015, 09:53:38 am »
Lot of work to remove em
So most go to the crusher with the frame
Look around on ColoradoK5.com
And I think BDS makes hangers as well
We just sent a frame to the crusher with springs still on it
