Engine/Drivetrain
no power under acceleration
Topic: no power under acceleration (Read 3537 times)
bigchevyc30
the pig
March 20, 2015, 09:35:17 pm »
Ok i have a 89 R2500 suburban it has a 350tbi/sm465 motor trans combo. most the time when im going to accelerate it doesnt seem to have much power behind it but there are some time when it shows its true get up and go and is fin but most the time its lack lustered for power. I know its not the clutch slipping as it was just replaced 3 months ago. when it seems to not have any power it wil sometimes pop through the exhaust. the timing on it is set to zero as per factory setting but i dont know what to look for after that. Any help would be greatly appreciated. heres a pic of what it looks like also
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Re: no power under acceleration
March 20, 2015, 11:44:37 pm »
couple questions, does you check engine light come on when you first turn the key "on"? do you have any codes?
bigchevyc30
the pig
March 21, 2015, 12:42:56 am »
it come on but goes off once started and only code it shows is 12 when doing the blink cde which is basically to tell you its testing right
March 22, 2015, 12:49:18 pm »
What does the fuel spray look like? Fuel pressure? How is the ignition parts?
bigchevyc30
the pig
March 22, 2015, 06:55:22 pm »
not sure about fuel spray or fuel pressure. it has all new fuel pump, dist, coil, icm, plugs and wires. i know it surges when idling.
March 25, 2015, 12:01:11 am »
Check your pressure and report.
Engine/Drivetrain
