Author Topic: Volt meter moves when blinker is on  (Read 8289 times)
Offline MaxmillianS
« on: March 23, 2015, 04:59:16 pm »
Like the title says when I have my blinkers on the volt meter moves about a cm every time they blink, think its just a bad ground?
Re: Volt meter moves when blinker is on
« Reply #1 on: March 23, 2015, 06:34:14 pm »
its normal as far as i know. think of it like this you alt doesnt just produce 14 volts all the time, it produces whats needed i.e. 14.1 volts just running vs 14.1 volts with the headlights on. it puts out 14.1 volts depending on the draw and it takes a split second for the alternator to sense how much draw your putting on it. so when the volt needle moves its because of that slight delay
Offline enaberif
« Reply #2 on: March 23, 2015, 07:48:05 pm »
Blinkers shouldn't make a volt meter move at all. Technically the only time you should see a volt meter change is under extreme heavy draw like power windows.
Offline blazer74
« Reply #3 on: March 23, 2015, 09:11:01 pm »
Possible diode in the alternator
Offline MaxmillianS
« Reply #4 on: March 24, 2015, 12:52:54 pm »
Alternator is brand new as of a month ago
Offline blazer74
« Reply #5 on: March 25, 2015, 05:28:19 am »
Was it doing this prior to the alt change?
« Reply #6 on: March 25, 2015, 06:00:37 am »
put a volt meter on the battery and see if it really does drop. could be a bad ground, but i know most if not all of my trucks do this
Offline enaberif
« Reply #7 on: March 25, 2015, 11:52:52 am »
LOL then you got a problem somewhere. This is not normal behavior.
« Reply #8 on: March 25, 2015, 03:33:57 pm »
oh i have a lot of problems lol
Offline Shifty
  • I bleed Bowtie red...
« Reply #9 on: March 26, 2015, 12:29:21 pm »
My 87 V30 and 87 Z/28 both do this....it may not be normal, but the Z/28 has had the same alternator for about 50k, battery 4+ years.
98 C2500 ext cab longbed
Offline frotosride
    • WFO CONCEPTS
« Reply #10 on: March 26, 2015, 06:02:47 pm »
Because of the wiring design there are often voltage drops in the cab. Like Irish-Alley said the alternator puts out varying voltage. If you have a three wire alternator then the small red wire that goes directly to the positive output lug is the voltage sensing wire. If you relocate this wire to the cab end of the wiring harness you will notice a drastic increase in electrical performance. The sensing wire works OK in the factory location but with most major loads under the hood being so close to the battery it. Cannot sense a large drop inside the cab.
