Author Topic: Another bad rear wheel bearing in 5 months  (Read 4460 times)
Offline mcintyrederek
  • Rookie
« on: March 25, 2015, 05:45:46 pm »
Hmmm... do you think this could have anything to do with the wheel bearing going out AGAIN in just 5 months?  How does a hub get warped?  What's the best solution - just buy two new axle rods and be done with it?
https://www.youtube.com/watch?v=F9aO-QqZTKs&feature=youtu.be
1986 C-10 Silverado 350 CI 260 HP, Edelbrock 1405, TH400, 2.73's - rescued from the junkyard - Farm Truck, daily driver!
Offline Engineer
Re: Another bad rear wheel bearing in 5 months
« Reply #1 on: March 25, 2015, 07:07:22 pm »
You have a bent axle.
Replace the axle shaft. Should be good to go.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
  • Rookie
« Reply #2 on: March 25, 2015, 08:51:06 pm »
What causes a bad axle other than a wreck?
I'm desperate and don't have time to fool with the junkyard.  I'm going to order a new rod tomorrow.
Offline Engineer
« Reply #3 on: March 25, 2015, 09:19:41 pm »
Overloading.
But most likely a wreck.
  • Rookie
« Reply #4 on: April 02, 2015, 12:17:28 pm »
New "Dorman" brand axle shaft came complete with new studs, bearing, and seal.  Take a look at where the old one was warped bad enough to cut a groove in it the depth of a match stick.
Offline enaberif
« Reply #5 on: April 02, 2015, 12:53:13 pm »
Holy crap that thing is DONE! Between the metal flattened and the heat scorned metal... That thing was rubbing for some time lol.
  • Rookie
« Reply #6 on: April 02, 2015, 03:06:33 pm »
Yeah I know..  the first time I changed the bearing it was not that bad..  I was in a hurry and didn't notice the flange was warped.  The 2nd time, I guess the bearing was newer and harder than the axle so the axle had to give.  Anyway, been driving it like this for quite some time.  New tires, axle rod, bearings all the way around, and all new shocks and this thing drives/sounds better than I would have ever imagined..
