Author Topic: SM 465 Parts questions  (Read 3212 times)
Offline HACK
« on: March 28, 2015, 01:28:11 pm »
I had a clutch issue with my truck I Pushed in the pedal and things never quite worked right after a cracking noise and some misc. pieces seemed to move about.  I assumed it was a throw-out bearing that came apart due to some noise I had been hearing previously to this happening. (Especially when cold)  Anyway I got it pulled apart yesterday and found that the bearing was still intact, however a cylindrical tube that extends over the input shaft has cracked and is broken free from the tranny housing.  I assume its part of the input shaft bearing and seal.   My main question is what is this part called exactly and can you get something like that at an autoparts store.  Is there a better place to get that kind of part.  Any info would be helpful.  I would like to replace the input and output shaft seals/bearing while I have it out also.  Thanks for reading.
« Last Edit: March 28, 2015, 08:34:37 pm by HACK »
1984 Custom Deluxe 1500 Small Block 400 w/ Edlebrock Quadrajet & A Muncy 4 Speed.
Offline bake315
Re: SM 465 Parts questions
« Reply #1 on: March 29, 2015, 11:37:54 pm »
Sounds similar to an issue I addressed with my '74.  When I first got it, it shifted okay, but made a horrible racket whenever the clutch was engaged.  Anyway, what I suspect you're seeing as a "cylindrical tube" is the same as I discovered; the interior section of the input shaft/throwout bearing that directly contacts the shaft itself. It apparently seized on the shaft, snapping the bearing into two pieces.  Incredibly, the shaft and everything else was fine. New bearing and it was good to go.
Be very careful when torquing down the input shaft housing when you replace the seals - it is rather brittle, and will crack around the bolt holes if overtightened.
Good luck,
bake315
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline Mario
« Reply #2 on: March 31, 2015, 12:24:49 pm »
As "bake315" stated it's the "input shaft housing". The throwout bearing slides back and forth on this shaft as you depress the clutch pedal, so it needs a light coating of grease. I would imagine that at some point the throwout bearing seized and tried to spin the shaft, and that's no good.
Mario
Santa Cruz, NM
1972 C10 4x4 350 350TH NP205
1981 K20 355 NV4500 NP208 GM14SF GM10
2005 3500 Duramax Allison 5spd
