Author Topic: 5-6 inches of lift for a daily driver that rides nice?  (Read 31487 times)
Offline 84Silverado4x4
Re: 5-6 inches of lift for a daily driver that rides nice?
« Reply #15 on: April 01, 2015, 09:39:31 pm »
Is there an amount of spring lift with a block combo that would be best for ride?  Stock leaf 6 inch block?  2 inch leaf 4 inch block? or some other combo. 4 inch leaf 2 inch block?
84 Silverado Reg Cab Shortbox 4x4
4" lift with 35's
5.3 vortec, 4l60e, np208, dana44, GM 12 bolt
Offline timthescarrd
« Reply #16 on: April 01, 2015, 10:32:47 pm »
All things being equal (such as stiffness, metal density, etc, which they aren't) The flatter the spring, the smoother the ride. That being said, blocks over 4 inches are generally frowned upon due to structural integrity.  A four inch shackle flip, with two inch blocks and stock arched springs in the back should give you the best ride (assuming good quality springs)
« Reply #17 on: April 01, 2015, 11:12:17 pm »
Someone stated that if I planned to tow a shackle flip may not be a good idea.  I don't plan to tow a lot or often but a may pull a open car trailer with a 3,500lb car once in a great while and maybe a small ATV trailer.  Should I stay away from the shackle flip?  Also where would be a good place to buy a quality spring in factory arch or maybe a 2-4" lift?
4" lift with 35's
« Reply #18 on: April 02, 2015, 12:15:17 am »
the problem i see with a shackle flip is it moves the axle forward a good bit. idk if there is different brands or what but a buddy of mine did one on his truck and before i even knew how he lifted it, i noticed the rear axle was no longer centered and asked if it was a shackle flip he confirmed that it was.
heres a picture i found online a while ago
« Reply #19 on: April 02, 2015, 12:10:30 pm »
I haven't done any of this myself so it's all speculation, but from information I've gathered, skyjacker soft-rides are the gentlest, flatter springs are better, so if you wanted to do a 6" lift for a soft ride,get two sets of Skyjacker CR12S 2" lift rear springs, then do the 52" rear conversion to the front, and 4" blocks in the rear, that should put you at 5-6 inches, plenty to clear 35s (you can clear 35s on 4" lift but will get rubbing if you flexing the suspension much)
Irish is right on the shackle flip moving the rear axle forward, it does this because it only moves the rear of the leaf spring down while the front stays the same, thus offsetting or tilting the axle forward.
Offline Greybeard
« Reply #20 on: April 05, 2015, 05:04:05 pm »
When you say 35's, do you mean the size embossed on the side of the tire (advertised size) or the actual size as measured on a rim with no weight on it? My experience is that almost no tire is as big as the advertised size embossed on it. Tire company's round up substantially. And metric sizes are not even close. Do an eyeball measure front to back to see what the actual tire size is. A 35 will likely be about 33-34 inches in diameter. A 1" lift will cover that easy enough for just street driving,  2-4" if you go off-road. The 1" can be accomplished with a zero lift spacers in front and back with new stock sized springs (the name zero lift is a misnomer because although they do not add to the springs ability to hold up a load they do take up space between the springs and the axles creating lift like a block). And the 2-4" with new 2" front springs (and possible rears) or a 4" or 2" block with stock or 2" springs in back respectively.
Or just return the truck to stock and put a hated body lift under it. (hated because I hate body lifts...YMMV).
« Reply #21 on: April 06, 2015, 12:19:36 pm »
yes my stated tire size is 35x12.50-18.  But they measure closer to 33.5-34" in diameter.  They are close to 3/4 tread and I run around 32psi in them to help save ride but they are load range E and I think they are supposed to have closer to 50psi in them or maybe 80?.
4" lift with 35's
Offline ehjorten
« Reply #22 on: April 06, 2015, 01:30:19 pm »
On my 8" lifted V3500 I did the geometry for the shackleflip and found that at 8" of lift it moved the axle forward about 2"!  That being said, they make offset add-a-leafs to move the axle back about 1".  My final solution I think will be to have AlCan or ORD make me a custom set of springs and just move the axle center back so that it is centered!
Additionally...the shackleflip does something else too...it moves the pinion angle up about 8° so you will need shims also, or cut and re-weld the perches!
At stock ride height a shackleflip will move the axle forward about 1".  At a 4" lift it will move the axle forward about 1.5" versus just a 4" block (the reason for this is that the pad actually faces backwards a few degrees, so if you just add a block it will actually move the axle backwards slightly).  It will always rotate the pinion up ~8.4°
« Last Edit: April 06, 2015, 01:46:57 pm by ehjorten »
-Erik-
« Reply #23 on: April 08, 2015, 07:42:00 am »
I guess I'm not yet sure what I should do.  I bought a four wheeler over the weekend and used the truck to pick it up.  The ride was rough as usual on the way to get it but with the four wheeler in the back it rode like a dream :).  I'm just wondering if I should do some spring/block combo in the rear to get to the 5-6" lift in the rear and maybe remove a leaf in the front?
4" lift with 35's
« Reply #24 on: April 11, 2015, 07:55:52 am »
What and where should I get new rear springs for the rear and stock height or with some lift?  How big of block?
4" lift with 35's
Offline roundhouse
« Reply #25 on: April 12, 2015, 11:22:31 am »
I'd remove a couple of te leafs from the bottom of the pack and give it a test drive
Offline Greybeard
« Reply #26 on: June 12, 2015, 03:07:00 am »
In order to brighten up this half dead thread I would say that the reason the axle is moved forward the amounts stated is due the fact that at full expected compression the axle will move rearwards that far. Only the rear of the springs move so the geometrics means that movement has to go somewhere. 8" lift at the halfway point means that in four inches of travel the axle needs to move 2 " rearwards. If you take the springs near to flat with that much lift you might consider having extra spring packs in the garage. No guarantees they will bend but they won't like it much if done too often. But it really depends on the type lift and number of leaves in it. I had my Trailmaster 6" lift springs bottomed so many times I couldn't count if I wanted to. But they had about ten leaves each and six inches isn't much lift anyway with that much leaf lift.
As for the load rating of a tire, that is a moot point unless you are hauling heavy loads. All that means is the tread doesn't get hot. The real issue is the air pressure. I have ten a ply rating (with three actual sidewall and four tread plies) and they say about 65 psi on the sidewall. I run them on my 3/4 ton Ram at about 30 psi and that is likely still overinflated for the truck. A quick math cipher says if the tire is capable of carrying say 3,400lbs, on ice multiply that by 4....3,400 X 4 =13,600lbs. Is that how much your truck weighs wet? Probably not. So one and quarter tires will carry the entire truck with extra capacity for your favorite cold beverages on ice. The only time a tire needs to be inflated to capacity is when the tire is carrying a maximum capacity load. My old Micky-T 39-15/15 Baja's I had were on a shorty GMC. Sidewall psi said something over 50 psi IIRC, I ran them from St. Louis to Colorada many times with 13 psi (all the time even off road actually, I hated airing back up). When I was young and had all the time in the world, I would take sidewalk chalk and go to a flat asphalt parking lot and put a good heavy stripe of chalk across the tread width. Then I would drive in figure eights slowly starting with the tire fully aired up. Of course Baja's were belted tires not radials. Anyway, this normally showed that the tire was overinflated at normal sidewall pressure. As I aired down I continued to do the figure eights driving slowly until the entire width of chalk was removed in one figure eight. That was the pressure I ran from then on out. I only did this on the rear tires though. I would just add about 2psi to the fronts because of engine weight and steering effectiveness. I've actually never tried this on a radial tire so YMMV. I just do a simple mental calculation and then guess these days. My truck weighs about 5,000 give or take, the tire rating is X divided by 4. The answer gives me the the approx. weight each tire is actually carrying. turn this into a percentage of the max inflation and that is the psi necessary for the truck equally, I give the rear slightly less and the front slightly more. But it can get more complicated than that because of the transfer case. If the truck bucks in 4-low on a hard surface (going in a straight line) the front and rear are not turning at the same speed. Then is when it needs fine tuning.
BTW- doing all this sounds like a pain in the ass, and it is. But the tradeoff is a more comfortable ride and decreased wear on the tires. If a tire wears more in the middle than along the edges, it's probably overinflated.
Offline enaberif
« Reply #27 on: June 12, 2015, 08:49:05 am »
And to add to Greybeards post I would like to say all these reasons are exactly why I am choosing NOT to do a shackle flip.
I would rather spend a few dollars more and get proper springs to ensure my driveline geometry doesn't get all wonky and if needed just get some heavy duty shackles and be done with it.
« Reply #28 on: June 26, 2015, 03:21:22 pm »
I run fairly low tire pressure around 30-35 psi to help with ride and better tire wear.  I am good with the overall height of the lift on the truck and I am going to try some skyjacker Hydro 7000 series shock to see how it rides with those.  I think the front set-up is fine however if my ride doesn't improve much a may try a different rear spring or spring and block combo.
4" lift with 35's
« Reply #29 on: July 09, 2015, 12:20:41 pm »
I switched to the skyjacker shocks and although the truck still rides pretty rough I will say just changing the shocks to the skyjacker 7000 series from whatever the rough country shocks were made a big difference.  It is much improved however I will probable need to change out at least the rear springs with something else to get it to where I like it.
4" lift with 35's
