Author Topic: firewall electrical connectors  (Read 6819 times)
Offline Boxchevrolet
« on: March 29, 2015, 12:42:47 pm »
hello i am new to the forum and i just bought a 83 chevy k10 350 and i opened the hood and on the driverside firewall where the fuse box is there is connectors that arnt connected to anything, can someone tell me what these connectors go toß
Offline Takilma
  • Newbie-
Re: firewall electrical connectors
« Reply #1 on: March 29, 2015, 02:39:47 pm »
Some might be for options not installed on your particular rig (?) Why not take a picture and post it here, some of these guys will probably know it exactly.
« Reply #2 on: March 29, 2015, 06:16:53 pm »
heres a picture
Offline LTZ C20
« Reply #3 on: March 29, 2015, 06:43:17 pm »
Do you have a wiper motor/washer pump installed? The 2 in your hand look to be for the wiper motor and washer pump, they should be 1 unit with 2 plugs.
LTZ Cheyenne C20
« Reply #4 on: March 29, 2015, 07:13:15 pm »
idk if they are installed, there is nothing near them for them to plug in to. could you put a picture of what they are support to go to?
Offline LTZ C20
« Reply #5 on: March 29, 2015, 08:19:08 pm »
The plastic square box that has all the wiring going into it is the firewall fuse box harness, the washer pump/wiper motor should be directly above it, between the brake booster and inner fender. I don't have a pic on my phone.
LTZ Cheyenne C20
« Reply #6 on: March 29, 2015, 09:48:29 pm »
thankyou apparently the truck doesn't have a windshield wiper motor , now on another note when i turn on my headlights the fuel guage move to below E, otherwise it shows the correct amount of fuel, do you have any idea what could be causing that?
Offline LTZ C20
« Reply #7 on: March 30, 2015, 01:08:26 am »
Here is the wiper motor and plugs, there are 3. These should clear things up for you.
As for your headlight question, I'de say best check the grounds first.
LTZ Cheyenne C20
« Reply #8 on: March 30, 2015, 07:56:19 pm »
thanks man
Offline LTZ C20
« Reply #9 on: March 30, 2015, 10:46:59 pm »
Welcome.
LTZ Cheyenne C20
