Author Topic: body mount  (Read 7115 times)
Offline Sierra4x4
body mount
« on: March 08, 2003, 07:40:00 pm »
seems like the passenger side body mount is getting weathered. Its about rusted through. How should I go about fixing it? get another and weld it on or what?
Body mount
« Reply #1 on: March 09, 2003, 09:22:00 am »
Is it the body mount or the washer on the bottom that holds the bottom rubber in place? Or are you talking about the mount that is riveted to the frame? If it is the bottom washer you can buy them from GM, and mabey aftermarket but not sure. if it is the mount on the frame I would try finding a used one but I think you can still get them from GM too. You can also buy Energy Suspensions or similar cab mount kit for under a $100.00, it comes with all six mounts but no bottom washers or bolts.
Offline Sierra4x4
its the mount
« Reply #2 on: March 09, 2003, 09:58:00 am »
its the mount on the frame. I may get one of those energy suspension jobs. I like knowing what im riding on, instead of assuming everything is good. thanks
Cab mount
« Reply #3 on: March 09, 2003, 07:21:00 pm »
You can weld a washer to the bottom of the mount. If you replace the mount you should grind the rivites off and bolt the new one on.
