Author Topic: v-6 and v-8 crossmembers the same?  (Read 7504 times)
Offline Stewart G Griffin
« on: April 02, 2015, 03:21:34 pm »
Does anyone know if the v-8 front crossmembers and the 85 and later v-6 front crossmembers are the same for 1/2 tons?
As you know i'm swapping in a 4.3 v-6 where the v-8 once was.  i can't figure out where the new 4.3 mounts go because NONE of the holes line up.
Re: v-6 and v-8 crossmembers the same?
« Reply #1 on: April 02, 2015, 07:46:53 pm »
The V-6 frame perches sit back and use the rear 2 holes on top, there is 3 total.  The side ear bolts to a hole by the top shock mount hole but I will try and put the V-8 ones in Saturday where the V-6 perches came from that I sold you.
« Reply #2 on: April 02, 2015, 08:04:24 pm »
Yeah, i'm just now getting to it because i had a lot of other stuff to deal with.  i think i'm going to try to drop the engine in tonight with the new mounts already attached to the engine and see where they end up.
i have a gut feeling that the crossmember IS the same.
« Reply #3 on: April 04, 2015, 09:54:40 am »
will update soon---almost there.
« Reply #4 on: April 04, 2015, 06:33:41 pm »
Got it in.  Will post pictures tomorrow.
« Reply #5 on: April 04, 2015, 06:36:52 pm »
Did the correct holes exist?
« Reply #6 on: April 04, 2015, 10:11:27 pm »
Ok, the rearmost hole on the crossmember (closest to the cab, farthest from front bumper) DID exist and DID match up.  However, i don't have any other holes in the frame and will have to drill 3 holes on each side.
When you think about it, this is not too surprising as the 90 degree v-6 did not exist when these trucks were originally designed and the engineers did know they'd be using this engine until the 85 model year.
« Reply #7 on: April 04, 2015, 10:16:01 pm »
What i meant was why would the holes be drilled in a pre-85 frame if the the engineers didn't know they'd be using the 4.3 until 85?
i was mistaken when i said none of the holes lined up.
« Reply #8 on: April 04, 2015, 10:20:16 pm »
Gotcha, I didn't know what year your truck was anyway.
« Reply #9 on: April 05, 2015, 09:51:54 am »
It's 83
« Reply #10 on: April 05, 2015, 10:37:30 am »
As you can see, the rearmost holes on the crossmember do line up:
Now i need to move the engine over to the right say .25" an inch to center it better.  Then i can start drilling.  Engine and trans are connected.
Any tips for drilling into the frame rail?
« Last Edit: April 05, 2015, 10:43:08 am by Stewart G Griffin »
