Author Topic: Rerun  (Read 10364 times)
Offline Tazman
Rerun
« on: April 02, 2015, 06:24:54 pm »
Awhile back I had mentioned that my truck would stumble at times and the check engine soon light would come on. After checking what the code was(33) I replaced the map sensor sense all my vacuum lines were good. It was not two days and it started again but mildly. That went on till today on the way home it did it so bad I pulled off the road. I was going up a hill and it did not have to power to clear it. I must include that this hill is were it acted up most of the time. Could the map sensor be bad again? Please let me know what you think !!
God BLESS AMERICA
Re: Rerun
« Reply #1 on: April 02, 2015, 07:50:18 pm »
I would question your fuel pressure/gas filter
Offline Tazman
Re: Rerun
« Reply #2 on: April 02, 2015, 08:33:48 pm »
Just changed the fuel filter two weeks ago. My question about the pressure why does it only do this on the way from work on the same stretch of road?
God BLESS AMERICA
Re: Rerun
« Reply #3 on: April 02, 2015, 08:53:51 pm »
Going uphill takes a little more fuel and if your fuel pump is getting weak?  Pull a heavy trailer around, you may have the same thing happen on a flat road.
Offline Tazman
Re: Rerun
« Reply #4 on: April 02, 2015, 09:06:39 pm »
The fuel pump was replaced a month ago. I will look into the pressure though.
God BLESS AMERICA
Re: Rerun
« Reply #5 on: April 03, 2015, 12:14:00 am »
Offline Tazman
Re: Rerun
« Reply #6 on: April 03, 2015, 07:53:04 pm »
33
God BLESS AMERICA
Re: Rerun
« Reply #7 on: April 03, 2015, 10:48:46 pm »
33 is the new codes that came on since this problem just started again?
Offline Tazman
Re: Rerun
« Reply #8 on: April 04, 2015, 10:16:01 am »
Yes
God BLESS AMERICA
Re: Rerun
« Reply #9 on: April 04, 2015, 04:06:03 pm »
Offline Tazman
Re: Rerun
« Reply #10 on: April 06, 2015, 07:01:04 pm »
Guys I might have found the problem. I was doing some checking of connections and found the cruise control rod had been disconnected. This is the one that comes from the TBI to the diaphragm of the cruise control. The truck ran much better today after connecting the rod back up. Disregard the arrows in the picture.
Thanks
God BLESS AMERICA
