Welcome
new member from Missouri
Topic: new member from Missouri (Read 7147 times)
vr4oaks
April 03, 2015, 10:11:53 pm »
Hey y'all I have a 79 c10 short bed with a 4bt Cummins that I've had for around five years now and it is a work in progress. Once I get to a computer I'll post some pictures.
-vr4oaks
1979 Chevy c10, Super HX30, POD Injectors, Timing and Fuel turned up, FASS 15 PSI Fuel Pump, BHAF, Autometer Pro-Comp 2 Boost and EGT gauges, 4" MBRP Dodge Cummins Exhaust, 12" 273 welded rear-end, max boost 40 pounds, max EGTs 1500, Hydroboost
Re: new member from Missouri
April 03, 2015, 10:52:11 pm »
welcome from maryland. im working on my
91 V3500 Crew cab cummins
theres a couple more of us that have 6bts in out truck but not many want to say 4 or 5
vr4oaks
April 03, 2015, 10:59:17 pm »
My buddy finished his 97 6bt 1 ton swap last year and loves it. With 20 degrees of timing, turned up ppump and an upgraded h1c he averages 20 mpg.
-vr4oaks
zieg85
April 04, 2015, 06:54:57 am »
Welcome from NW Indiana
vr4oaks
April 04, 2015, 08:58:29 pm »
The truck and how much can my truck safely tow, never mind the drive train, with a custom hitch? The hitch setup is going to be very similar to what my buddy did with his pulling truck.
-vr4oaks
vr4oaks
April 04, 2015, 08:59:41 pm »
The engine.
-vr4oaks
April 05, 2015, 12:28:46 am »
generally speaking you are limited to the drive train, brakes, tires, springs and frame size for towing. BUT in a custom hitch that might be the week spot. unless the welder knows what hes doing it might be less then you think till it breaks
April 05, 2015, 12:37:19 am »
a trailer hitch should be at the minimum for our trucks 5,000 lbs gross trailer weight but they can be up to 15,000 lbs GTW. its all on how theyre built. the c10 gvwr is going to be between 4900 and 6200. but even if you had a 15000 lb trailer hitch made your rear axle might not take 6000 lbs
vr4oaks
April 05, 2015, 12:40:52 am »
OK thanks.
-vr4oaks
Welcome
