Author Topic: Shock Absorbers  (Read 4015 times)
Offline 87project
Shock Absorbers
« on: April 04, 2015, 01:16:11 pm »
Gabriel budget with Bilstein dreams....  In all seriousness,  I think I want Rancho 5000's. I have the quad shocks up front. Do you guys have a better suggestion for my truck. No major off roading. 3" block lift in rear and 2.5" springs up front. Anyone know the part #s for my needs. Captkaos... do you have anything for me... I didn't see anything for my application in your store? I'm about to start pulling things apart... I hope those huge bolts holding the sway bar assembly are not froze up!!!
Thanks!
Offline Edemich
Re: Shock Absorbers
« Reply #1 on: April 05, 2015, 07:59:15 am »
Here is a link to determine which type of shock you need
http://www.4x4review.com/everything-you-wanted-to-know-about-shock-absorbers/
And just do a search on how to measure shock length.
You will need three measurements.   Static height from eye mount to eye mount,  bumpstop to suspension subtracted from static height gives you the compressed length of the shock you need and jack the vehicle up so your suspension is extended then measure to get your extended height.
Or measure your current shocks at extended and collapsed.  Once you have those measurements you can start shock shopping.  Good luck.
Dark Ming Blue 85' K10 w/355 SBC, Edelbrock top end kit with Scorpion Roller Rockers, 2001 14B FF w/4.56 gears, NV4500 5spd, One Piece Rear and Door Glass
Offline dronz
Re: Shock Absorbers
« Reply #2 on: April 11, 2015, 11:08:19 am »
bilstein 5100's are the way to go for lifted!! streetside auto has em cheap but they might not have all 4 of em in stock so call summit racing they will price match.
