Author Topic: hydroboost identification  (Read 15986 times)
Offline vr4oaks
« on: April 06, 2015, 01:29:44 pm »
I have a hydroboost system and it fits my truck with no modification to the mounting it or hooking up to my brake pedal and the guy that I got it from we don't talk any more, so I was wondering what year it's from and wear I can possible get a rebuild kit. It leaks where the arm attaches to the brake pedal. I can provide pictures if requested.
-vr4oaks
1979 Chevy c10, Super HX30, POD Injectors, Timing and Fuel turned up, FASS 15 PSI Fuel Pump, BHAF, Autometer Pro-Comp 2 Boost and EGT gauges, 4" MBRP Dodge Cummins Exhaust, 12" 273 welded rear-end, max boost 40 pounds, max EGTs 1500, Hydroboost
Offline LTZ C20
Re: hydroboost identification
« Reply #1 on: April 06, 2015, 01:56:10 pm »
Info on the truck would be good. Year, make, model, 1/2, 3/4 or 1 ton, 2wd or 4wd. Alot of models came factory with a hydroboost system. Pics help alot too.
LTZ Cheyenne C20
Offline vr4oaks
« Reply #2 on: April 06, 2015, 02:04:55 pm »
Sorry about that, 79 Chevy short bed c10. It didn't originally come on my truck. I'll provide pictures in about an hour or two.
-vr4oaks
Offline enaberif
« Reply #3 on: April 06, 2015, 02:09:47 pm »
The only trucks that usually came with hydroboost were 1 tons and diesels. If you find it in any other truck its usually placed in it specifically.
Offline vr4oaks
« Reply #4 on: April 06, 2015, 02:16:28 pm »
So would it be safe to say that my hydroboost came off of a 79ish truck and if so where can I find a rebuild kit, I've been searching but no good luck really.
-vr4oaks
« Last Edit: April 06, 2015, 02:22:06 pm by vr4oaks »
Offline enaberif
« Reply #5 on: April 06, 2015, 02:40:30 pm »
-vr4oaks
Hydroboost unfortunately came from a lot of different vehicles :(
Offline vr4oaks
« Reply #6 on: April 06, 2015, 05:48:30 pm »
Will this work?
-vr4oaks
Offline 78BIG-TEN
« Reply #8 on: April 07, 2015, 01:53:10 pm »
Never seen a rebuild kit only reman units
Offline vr4oaks
« Reply #9 on: April 07, 2015, 03:38:15 pm »
dang, I was hoping I could just rebuild it instead of having to buy a new one.
-vr4oaks
