Author Topic: Locking rear end options?  (Read 6909 times)
Offline jim.clark.52687506
« on: April 07, 2015, 12:38:52 pm »
What are my options for locking my 14bolt? The truck is a 84 K2500 hot 350/4x4/auto trans. I've used Detriots in the past but I don't like the 3/4 revolution slop the have when you put it in gear and it bangs. How do I tell what I have now if it has a factory posi or some such?
« Last Edit: April 07, 2015, 12:41:03 pm by jim.clark.52687506 »
Bone stock 84 K25 daily driver (on weekends)
Re: Locking rear end options?
« Reply #1 on: April 07, 2015, 12:59:02 pm »
lol the ¾ turn slop on the Detroit is normal? i thought that meant it was bad and ive took mine out before just cause of that
« Reply #2 on: April 07, 2015, 01:10:25 pm »
I knew it was normal but it just drove my crazy! The banging and jerking. Was thinking about an OX locker but they are expensive too
Offline 87max
« Reply #3 on: April 07, 2015, 08:59:29 pm »
Dollar for dollar you won't beat a Detroit. Good luck breaking one. Ya they make noise but are simple and bullet proof.
88 R30 lb7 transplant in progress
04 E350 6.0 studded & tuned work van
98 Taurus beater
Offline ehjorten
« Reply #4 on: April 08, 2015, 09:00:41 am »
ARB!
-Erik-
« Reply #5 on: April 08, 2015, 01:10:36 pm »
ARB are nice. I agree with you but I don't have onboard air. Dont want the hassle or added expence of it. Guess I'll jus do a banging Detroit or cheap out and do a spool.
Offline Edemich
« Reply #6 on: April 08, 2015, 10:31:15 pm »
Stock GM G80 for a 14 Bolt.  Limited Slip, no noise.  However it is referred to as the Gov Bomb by most off road communities.
However, if it's for light off roading might be a viable option.
Dark Ming Blue 85' K10 w/355 SBC, Edelbrock top end kit with Scorpion Roller Rockers, 2001 14B FF w/4.56 gears, NV4500 5spd, One Piece Rear and Door Glass
Offline Engineer
« Reply #7 on: April 09, 2015, 08:29:12 am »
First question is it a 10.5" FF 14-bolt? Or is it a 9.5" semi float 14-bolt. A 1984 3/4ton with a 350 would have been delivered with the semi-float 9.5". The most likely way it would have the full float is if it was swapped in.
Your options will be different depending on which axle you have.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #8 on: April 09, 2015, 08:55:33 am »
Guess I'll need to pop a hubcap and look at the axle end right? If I has bolts it's full if it's recessed it's semi?
Offline Engineer
« Reply #9 on: April 09, 2015, 10:13:35 am »
Correct.
Offline Mario
« Reply #10 on: April 09, 2015, 11:30:21 am »
I'll probably go with a TrueTrac when I get around to it.
Mario
Santa Cruz, NM
1972 C10 4x4 350 350TH NP205
1981 K20 355 NV4500 NP208 GM14SF GM10
2005 3500 Duramax Allison 5spd
« Reply #11 on: April 09, 2015, 12:05:03 pm »
Is the Tru track the little "clicker" ones that replace the spider gears? I've used them in jeeps before and never had any trouble with them with 36" tires. I had forgotten about them. They were cheap too comparatively
