Author Topic: C notch?  (Read 4907 times)
Offline nathan.zornes
  • under_constr
C notch?
« on: April 08, 2015, 11:44:43 pm »
Quick question fellas, I know a lot of you have done c notches and there are already discussions on here about it. Bit I want an opinion on my current task. I've notched my frame with 6" diameter 1/4" thick pipe and started welding it in. Question is do I need to box the backside in? And if so how big does the box need to be in length? Thanks
1977 Chevy C20 (Camper Special) 454 long bed, Lowered and loud. underconstruction.
Re: C notch?
« Reply #1 on: April 10, 2015, 09:17:48 pm »
I usually use thicker metal for the notch, I would box it out 6" on each side
  • under_constr
Re: C notch?
« Reply #2 on: April 11, 2015, 12:09:23 am »
I went ahead and boxed it in with couple scrap 1/4" angle I had laying around. Figured since the notch should have been bigger I would use the angle and plate the top of the frame. I'm putting on a step side short bed next week and will modify the bed supports to make up for the extra 1/4" in height.
